Старый 02.11.2013, 04:14   #1
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework new version released
Источник: http://blogs.msdn.com/b/axsa/archive...w-release.aspx
We have released the new version for Microsoft Dynamics AX 2012 Data Import/Export Framework. Besides the new features we added we have also moved DIXF to Foundation as part of Microsoft Dynamics AX 2012 R2 CU7.
What’s New :
  • Part of foundation layer in CU7.
  • 150 Entitiesout of the box ( 80+ new entities added)
    • Master Data
    • Reference Data
    • Journals
    • System Configuration data
    • Application configuration data – Parameters, Reference data, etc.
  • New Retail specific entities
  • New file types added for import as well as export
    • XML file – attribute and element based.
    • Excel file
  • Compare and copy entity data across companies
  • Copy entity data across companies
  • Support for exporting data in multiple formats – delimited, fixed width, XML and excel for bulk data.
  • Role based security and privacy extension for Entities and Processing Group
  • Securing Processing group by company.
  • Enhancements to custom entity creation
Download it now!
  • Microsoft Dynamics AX 2012 R2 Cumulative Update 7 (KB2885603 )
Key features
  • 150+ Entities out of the box
  • Support for creating custom entities using Custom entity creation wizard.
  • Import Entity data from multiple sources
  • Flat File – Delimited and Fixed Width
    • XML – XML file
    • Excel – Excel file
    • ODBC – external data bases , Excel files , etc.
  • Export Entity data from AX 2012 to
    • Other AX 2012 environments
    • Flat File , XML File and Excel file
  • Compare and Copy Entity data across Legal entities
  • Entity types – Entity, composite entity and flat table.
  • Mapper control
  • Parallel execution support from staging to target using Task Bundling
  • Folder as input for running periodic import - with functionality to move files to different folders (In Process, Error and Completed)
  • Error handling - skipping error rows , etc.
  • Set based support for staging to target
  • Default value Support
  • Number sequence Support
  • External Key mapping Support
  • · Source to Target in single step
  • · Multiple AOS support
.. and lot more.
Старый 02.11.2013, 11:22   #2
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Data Import Export требует 4.5 net framework !
Axapta book for developer
За это сообщение автора поблагодарили: gl00mie (1).
ax2012, dmf
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 15 Blog bot Dynamics CRM: Blogs 1 10.02.2016 10:26
dynamics-coe: Dynamics AX Export/Import Framework for Vendor balance migration Blog bot DAX Blogs 0 22.05.2013 20:13
emeadaxsupport: Preliminary Microsoft Dynamics AX 2012 R2 content now on TechNet and MSDN! Blog bot DAX Blogs 0 10.11.2012 08:20
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
Microsoft Dynamics CRM Team Blog: Update Rollup 5 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 2 27.10.2011 17:11
Часовой пояс GMT +3, время: 02:36.
