Старый 24.09.2013, 18:35   #1
Ion is offline
Ion
Я код переписал, мне не ясно почему если пишу так, то переменная содержит значение reguestGrid {...} Object, (FormUIControl)
var reguestGrid =Xrm.Page.ui.controls.get('new_dogovorGrid')._control;
А переменная reguestGrid = undefined, когда пишу таким образом document.getElementById("new_dogovorGrid") = [Object, HTMLDivElement]
var reguestGrid = document.getElementById("new_dogovorGrid")
function filterSubGrid() {
var Casko = 100000001;
var Osago = 100000000;
var reguestGrid1 = document.getElementById("new_dogovorGrid");
debugger;
if (reguestGrid != null)
if (reguestGrid .readyState != "complete")
setTimeout(filterSubGrid, 1000);
return;
else
return;
var accountValue = Xrm.Page.getAttribute("new_account").getValue(); //field to filter by
var ProductValue = Xrm.Page.getAttribute("new_insurance_product").getValue(); //field to filter by
var accountId = "00000000-0000-0000-0000-000000000000"; //if filter field is null display nothing
if (accountValue != null && (ProductValue == Casko || ProductValue == Osago)) {
var accountId = accountValue[0].id;
//fetch xml code which will retrieve all the accounts related to the contact
var fetchXml = "<fetch version='1.0' output-format='xml-platform' mapping='logical' distinct='false'>" +
" <entity name='new_request'>" +
" <attribute name='new_requestid' />" +
" <attribute name='new_insurance_product' />" +
" <attribute name='new_insuransepayment' />" +
" <attribute name='new_total_limit' />" +
" <attribute name='new_client_account' />" +
" <order attribute='new_insurance_product' descending='false' />" +
" <filter type='and'>" +
" <condition attribute='new_client_account' operator='eq' uitype='account' value='" + accountId + "' />" +
" <condition attribute='new_insurance_product' operator='eq' value='" + ProductValue + "'/>" +
" <condition attribute='new_stage' operator='eq' value='100000006' />" +
" <condition attribute='new_result' operator='eq' value='1' /> " +
" </filter>" +
" </entity>" +
"</fetch>";
if (typeof reguestGrid.control.setParameter != "undefined"){
reguestGrid.control.setParameter("fetchXml", fetchXml);
if (typeof reguestGrid.control.SetParameter != "undefined"){
reguestGrid.control.SetParameter("fetchXml", fetchXml);
Старый 24.09.2013, 18:41   #2
Ion is offline
Ion
Грид находится в отдельной вкладке, в разделе, и открыт постоянно, на форме он последний
Последний раз редактировалось Ion; 24.09.2013 в 18:55.
Старый 25.09.2013, 00:59   #3
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Добрый день,
Посмотрите - http://www.magnetismsolutions.com/bl...-%28polaris%29
Старый 25.09.2013, 18:54   #4
Ion is offline
Ion
Сделал как в примере, СРМ выводит сообщение: Недопустимый XML формат.
Вот лог ошибки, что к чему не ясно мне пока.
Unhandled Exception: System.ServiceModel.FaultException`1[[Microsoft.Xrm.Sdk.OrganizationServiceFault, Microsoft.Xrm.Sdk, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]: System.Xml.XmlException: Microsoft Dynamics CRM has experienced an error. Reference number for administrators or support: #044F499ADetail:
<OrganizationServiceFault xmlns:i="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.microsoft.com/xrm/2011/Contracts">
<ErrorCode>-2147220970</ErrorCode>
<ErrorDetails xmlns:d2p1="http://schemas.datacontract.org/2004/07/System.Collections.Generic">
<KeyValuePairOfstringanyType>
<d2p1:key>CallStack</d2p1:key>
<d2p1:value xmlns:d4p1="http://www.w3.org/2001/XMLSchema" i:type="d4p1:string"> в Microsoft.Crm.Application.WebServices.AppGridWebServiceHandler.ProcessRequestInternal(HttpContext context)
в System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
в System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean&amp; completedSynchronously)</d2p1:value>
</KeyValuePairOfstringanyType>
</ErrorDetails>
<Message>System.Xml.XmlException: Microsoft Dynamics CRM has experienced an error. Reference number for administrators or support: #044F499A</Message>
<Timestamp>2013-09-25T14:46:35.5114095Z</Timestamp>
<InnerFault>
<ErrorCode>-2147220991</ErrorCode>
<ErrorDetails xmlns:d3p1="http://schemas.datacontract.org/2004/07/System.Collections.Generic">
<d3p1:key>CallStack</d3p1:key>
<d3p1:value xmlns:d5p1="http://www.w3.org/2001/XMLSchema" i:type="d5p1:string"> в Microsoft.Crm.Query.EntityExpression.InternalDeserializeFromFetchXml(String xmlInfo, ParsingConditionValuesOption parsingOption)
в Microsoft.Crm.Application.Platform.Grid.GridDataProviderQueryBuilder.SetupQueryBuilder(QueryBuilder queryBuilder, View view)
в Microsoft.Crm.Application.Platform.Grid.GridDataProviderQueryBuilder.LoadQueryData()
в Microsoft.Crm.Application.Platform.Grid.GridDataProviderQueryBuilder.LoadData()
в Microsoft.Crm.Application.Platform.Grid.GridDataProviderBase.PrepareGridData()
в Microsoft.Crm.Application.Platform.Grid.GridDataProviderBase.PrepareData()
в Microsoft.Crm.Application.Controls.GridUIProvider.Render(HtmlTextWriter output)
в Microsoft.Crm.Application.WebServices.AppGridWebServiceHandler.GetRefreshResponseHtml(IGridUIProvider uiProvider, StringBuilder sbTemp)
в Microsoft.Crm.Application.WebServices.AppGridWebServiceHandler.Refresh(String gridXml, StringBuilder sbXml, StringBuilder sbHtml, Boolean returnJsonData)
в Microsoft.Crm.Application.WebServices.AppGridWebServiceHandler.ProcessRequestInternal(HttpContext context)</d3p1:value>
</ErrorDetails>
<Message>Invalid XML.</Message>
<InnerFault>
<ErrorDetails xmlns:d4p1="http://schemas.datacontract.org/2004/07/System.Collections.Generic">
<d4p1:key>CallStack</d4p1:key>
<d4p1:value xmlns:d6p1="http://www.w3.org/2001/XMLSchema" i:type="d6p1:string"> в System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
в System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
в System.Xml.XmlTextReaderImpl.ParseEndElement()
в System.Xml.XmlTextReaderImpl.ParseElementContent()
в System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
в System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
в System.Xml.XmlDocument.Load(XmlReader reader)
в Microsoft.Crm.Query.XmlDomHelper.LoadXmlInfo(String xmlInfo)
в Microsoft.Crm.Query.EntityExpression.InternalDeserializeFromFetchXml(String xmlInfo, ParsingConditionValuesOption parsingOption)</d4p1:value>
</ErrorDetails>
<Message>System.Xml.XmlException: Microsoft Dynamics CRM has experienced an error. Reference number for administrators or support: #5B878BDA</Message>
<InnerFault i:nil="true" />
<TraceText i:nil="true" />
</InnerFault>
</InnerFault>
</OrganizationServiceFault>
Старый 25.09.2013, 19:42   #5
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Можете после
Код:
" </filter>" +
" </entity>" +
"</fetch>";
вставить alert, который покажет фильтр?
В ProductValue - текстовое значение? Точно не лукап?
Старый 25.09.2013, 21:13   #6
Ion is offline
Ion
Вот он:
<filter type='and'>
<condition attribute='new_client_account' operator='eq' uitype='account' value='{BAF1A4C8-3C03-E311-8620-00155D001525}' />
<condition attribute='new_insurance_product' operator='eq' value='100000000'/>
</filter>
</link-entity>
</entity>
</fetch>
Вроде все корректно. Непонятно.
Нет, там тип OptionSet.
Старый 25.09.2013, 21:46   #7
Ion is offline
Ion
Разобрался, всем спасибо)
Старый 26.09.2013, 00:06   #8
Ion is offline
Ion
Надо делать по этому примеру. Реально выручило.
Спасибо a33ik
Не работает простой отчет. Dzam Dynamics CRM: Разработка 4 20.10.2015 11:46
axforum blogs: Правила поиска дубликатов (Duplicate Detection Rules) CRM 2011. Как это работает и почему правила иногда автоматически становятся черновиками? Blog bot Dynamics CRM: Blogs 0 11.03.2013 20:11
Не работает фильтрация по сроку в действиях DimaV Dynamics CRM: Функционал 9 29.04.2010 06:48
CRM Deployment Manager. User manager не работает kras Dynamics CRM: Администрирование 18 05.12.2006 17:34
CRM очень медленно работает... CRM30 Dynamics CRM: Администрирование 12 26.07.2006 18:01
Часовой пояс GMT +3, время: 16:06.
