AOS Cannot load assemblies - AX2012 R2
Господа подскажите что это за ошибки и как с ними бороться?
При старте АОС в Windows Application Log добавляются такие записи с типом Information: Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.MatrixPivotGrid, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Analytics, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Client.Controls, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Frameworks.ProductConfiguration, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.Kernel.Client, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Workflow.Metadata.Wizard, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.AX.Framework.Workflow.Model.Design, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.StoreConnect.MessageTreeControl, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. Object Server 01: Could not load assembly 'RetailControls, Version=5.3.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Object Server 01: Could not load assembly 'Microsoft.Dynamics.Retail.StoreConnect.TransAutomClient, Version=0.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35, processorArchitecture=x86' or one of its dependencies. Could not load assembly 'EInvoiceCFDI_MX.dll.config' or one of its dependencies. Object Server 01: Could not load assembly 'ElectronicFiscalDocument_BR.dll.config' or one of its dependencies. ДЛЛки эти вроде как клиентские и почему их АОС вообще пытается загрузить загадка. |
| За это сообщение автора поблагодарили: Logger (1). | |
up
установка SQL AMO решило проблему
| За это сообщение автора поблагодарили: AlGol (3), Logger (3). | |
Большое спасибо, это единственный пост где я нашел упоминание об AMO для того, чтобы заставить работать dll Microsoft.Dynamics.AX.Framework.Analytics.
Везде написано только об установке SMO, но это не помогало. Общий комплект пакетов которые заставили работать форму Серверы Анализа на терминальном сервере где запускался клиент AX2012R2 получился такой:
Ален ноби, ностра алис. Что означает - если один человек построил, другой завсегда разобрать может. |
| За это сообщение автора поблагодарили: Logger (5). | |
