Чайный пьяница
Я ж пишу. Доступ через браузер к IFD деплойменту есть. Т.е. проблемы с DNS, сертификатами и прочее не должны быть причиной неработоспособности.
При попытке подключить Outlook к CRM получаю следующую ошибку: Код: 08:25:16|Verbose| Method entry: Microsoft.Crm.Application.Outlook.Config.ServerForm._testConnectionButton_Click 08:25:16|Verbose| Method entry: Microsoft.Crm.Application.Outlook.Config.ServerForm.TestConnection 08:25:16|Verbose| Method exit: Microsoft.Crm.Application.Outlook.Config.ServerForm.TestConnection 08:25:16|Verbose| Method exit: Microsoft.Crm.Application.Outlook.Config.ServerForm._testConnectionButton_Click 08:25:18| Error| Error connecting to URL: https://something.com:444/XRMServices/2011/Discovery.svc Exception: System.InvalidOperationException: Metadata contains a reference that cannot be resolved: 'https://something.com:444/XRMServices/2011/Discovery.svc?wsdl'. ---> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, Exception exception) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.TlsStream.CallProcessAuthentication(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result) at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size) at System.Net.ConnectStream.WriteHeaders(Boolean async) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at System.ServiceModel.Description.MetadataExchangeClient.MetadataLocationRetriever.DownloadMetadata(TimeoutHelper timeoutHelper) at System.ServiceModel.Description.MetadataExchangeClient.MetadataRetriever.Retrieve(TimeoutHelper timeoutHelper) --- End of inner exception stack trace --- at System.ServiceModel.Description.MetadataExchangeClient.MetadataRetriever.Retrieve(TimeoutHelper timeoutHelper) at System.ServiceModel.Description.MetadataExchangeClient.ResolveNext(ResolveCallState resolveCallState) at System.ServiceModel.Description.MetadataExchangeClient.GetMetadata(MetadataRetriever retriever) at System.ServiceModel.Description.MetadataExchangeClient.GetMetadata(Uri address, MetadataExchangeClientMode mode) at Microsoft.Xrm.Sdk.Client.ServiceMetadataUtility.RetrieveServiceEndpointMetadata(Type contractType, Uri serviceUri, Boolean checkForSecondary) at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1..ctor(Uri serviceUri, Boolean checkForSecondary) at Microsoft.Xrm.Sdk.Client.ServiceConfigurationFactory.CreateConfiguration[TService](Uri serviceUri) at Microsoft.Crm.Outlook.ClientAuth.ClientAuthProvidersFactory`1.GetAuthProviderForDeployment(Uri endPoint, Credential credentials, Uri webEndPoint) at Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo.DeploymentInfo.ValidateAuthProvider() at Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo.SortAndValidateDeployments() 08:25:18| Error| Exception : Metadata contains a reference that cannot be resolved: 'https://something.com:444/XRMServices/2011/Discovery.svc?wsdl'. at Microsoft.Crm.Application.Outlook.Config.DeploymentsInfo.LoadOrganizations(AuthUIMode uiMode, Form parentWindow) at Microsoft.Crm.Application.Outlook.Config.ServerForm.LoadOrganizations(Boolean forceUI) at Microsoft.Crm.Application.Outlook.Config.ServerForm.<InitializeBackgroundWorkers>b__0(Object sender, DoWorkEventArgs e) at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e) at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument) 08:25:18| Error| Exception : The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. at System.Net.HttpWebRequest.GetResponse() at System.ServiceModel.Description.MetadataExchangeClient.MetadataLocationRetriever.DownloadMetadata(TimeoutHelper timeoutHelper) at System.ServiceModel.Description.MetadataExchangeClient.MetadataRetriever.Retrieve(TimeoutHelper timeoutHelper) Это может означать, что есть проблемы с сертификатом, но сертификат помещён в указанные хранилища компьютера, с которого запускаю Outlook (Личные и Доверенные центры сертификации). Возможно я упускаю что-либо?
https://something.com:444/XRMService...overy.svc?wsdl
а эта ссылка из вне открывается вообще через браузер? и ошибок нет в IE? Нужно добиться, чтобы с клиентской машины через IE был нормальный доступ, то есть без запроса типа "Ошибка в сертификате...." "Продолжить" http://clip2net.com/s/5dLWXZ http://clip2net.com/s/5dLYeV Вопрос в том, что в IE вы можете нажать "Продолжить" и спокойно дальше проаутентифицироваться. При подключении по Outlook клиенту, это не прокатит. Не произойдет нормальной аутентификации при доступе к службе Discovery.svc. Пока только такие мысли ( |
Так же, не забывай что Outlook ищет Discovery сервис. Убедись что он доступен по адресу. Возможно что-то криво настроено и IIS адресует страницу куда-то не туда.
http://fixrm.wordpress.com, снятие/наведение порчи. Быстро, дорого, гарантия. ![]() ![]() |
Опции просмотра | |
