Старый 25.05.2013, 01:15   #1
dynamicscare: Using Excel to Update Demand Forecasts in Dynamics AX 2012
Источник: http://dynamicscare.com/blog/using-e...amics-ax-2012/
Dynamics AX has an add-on for Microsoft Excel that allows you to retrieve data from Dynamics AX, and also publish changes back to the database in a controlled way. You can use this to give users a simpler way to manipulate the information in the database. As an example, you can use this to create [...]
Старый 27.05.2013, 01:04   #2
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Страшный секрет: в AX2012 R3 нас ждет реинкарнация Demand Planner, на этот раз через Analysis Services --> Excel --> Sales forecast.
Dynamics AX Sustained Engineering: Announcing Cumulative Update 4 for Microsoft Dynamics AX 2012 & Microsoft Dynamics AX 2012 Feature Pack 1 Blog bot DAX Blogs 0 05.12.2012 01:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 4 Blog bot Dynamics CRM: Blogs 0 24.09.2011 01:16
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
Часовой пояс GMT +3, время: 19:13.
