Старый 24.05.2013, 17:26   #1
user_ax is offline
user_ax
Аватар для user_ax
599 / 39 (3) +++
Если джойнить 2 таблицы - всё замечательно, когда пытаюсь приджойнить третью - qbds валится в null.
Queryrun main_query(boolean _count_query = false)
    Query query   =      new Query();
    QueryBuildDataSource qbds;
    qbds  = query.addDataSource(tablenum(VendInvoiceTrans));
    qbds.addSortField(fieldnum(VendInvoiceTrans,ItemId));
    qbds.addSortField(fieldnum(VendInvoiceTrans,InternalSp));
    qbds.addSelectionField(fieldnum(VendInvoiceTrans,Qty), SelectionField::Sum);
    qbds.orderMode(OrderMode::GroupBy);
    qbds  = qbds.addDataSource(tablenum(VendSpListTrans));
    qbds.addLink(fieldnum(VendSpListTrans,InternalSp),fieldnum(VendInvoiceTrans,InternalSp));
    qbds.joinMode(JoinMode::InnerJoin);
    qbds = query.dataSourceTable(tableNum(VendSpListJour));
    qbds.addLink(fieldnum(VendSpListTrans,InternalSp),fieldnum(VendSpListJour,InternalSP));
    if (datefromstr && datetostr)
        qbds.addRange(fieldnum(VendSpListJour,SpDate)).value(SysQuery::range(datefrom.value(),dateto.value()));
    if (vendaccountstr)
        qbds.addRange(fieldnum(VendSpListJour,OrderAccount)).value(SysQuery::value(vendaccountstr));
     //если введён регистранионный номер договора
    if (rcontractaccountstr)
        qbds.addRange(fieldnum(VendSpListJour, RcontractAccount)).value(SysQuery::value(rcontractaccount.value()));
    //если введён Владелец
    if (emplidstr)
        qbds.addRange(fieldnum(VendSpListJour, Emplid)).value(SysQuery::value(emplid.value()));
    switch(spclosedstr)
        case (AllOpenPosted::All):
           qbds.addRange(fieldnum(VendSpListJour,SpClosed));
        break;
        case (AllOpenPosted::Open):
           qbds.addRange(fieldnum(VendSpListJour,SpClosed)).value('1');
        break;
        case (AllOpenPosted::Posted):
           qbds.addRange(fieldnum(VendSpListJour,SpClosed)).value('0');
        break;
        default:
        break;
    qbds = query.dataSourceTable(tablenum(VendInvoiceTrans));
    if (_count_query)
        qbds.addSelectionField(fieldnum(VendinvoiceTrans,RecId), SelectionField::Count);
    qbds = query.dataSourceTable(tablenum(VendSpListTrans));
    return (new QueryRun(query));
валится на qbds = query.dataSourceTable(tableNum(VendSpListJour));
Если заккоментировать весь кусок от qbds = query.dataSourceTable(tableNum(VendSpListJour));
и до конца switch - всё замечательно работает.
Уважаемый maldini, не знаете, в чём причина?
group by, query, группировка
AX 2012 Наследование таблиц. Краткое описание механизма sukhanchik DAX: Программирование 32 21.09.2018 17:56
emeadaxsupport: Calling the Query Service Blog bot DAX Blogs 0 18.02.2012 01:13
AIF: OData Query Service Blog bot DAX Blogs 0 24.08.2011 09:11
jinx: Dynamics AX – Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 04.05.2009 14:05
Часовой пояс GMT +3, время: 12:19.
