1. конфига TMG
http://blogs.technet.com/b/sooraj-se...-crm-page.aspx 2. конфига правил user root wheel; worker_rlimit_nofile 50000; working_directory /root; worker_rlimit_core 2048M; worker_processes 16; events { worker_connections 10240; } http { client_max_body_size 256m; server_tokens off; #log_format evrika_long '$remote_addr\t$remote_user\t[$time_local]\t$host\t$server_addr\t$request\t$status\t$body_bytes_sent\t$http_referer\t$http_user_agent\t$http_x_forwarded_for\t$request_time-$upstream_response_time'; log_format evrika_long '$remote_addr\t$remote_user\t[$time_local]\t$host\t$server_addr\t$upstream_addr\t$request\t$status\t$body_bytes_sent\t$request_length\t$http_referer\t$http_user_agent\t$http_x_forwarded_for\t$request_time\t$upstream_response_time\t$http_cookie'; ssl_certificate thawte-2012.pem; ssl_certificate_key thawte-2012.pem; ssl_session_timeout 5m; #ssl_protocols SSLv3 TLSv1 SSLv2; ssl_protocols SSLv3 TLSv1; #ssl_ciphers ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP; ssl_ciphers ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+EXP; ssl_prefer_server_ciphers on; types { text/html html htm shtml; text/css css; text/xml xml; image/gif gif; image/jpeg jpeg jpg; application/x-javascript js; application/atom+xml atom; application/rss+xml rss; text/mathml mml; text/plain txt; text/vnd.sun.j2me.app-descriptor jad; text/vnd.wap.wml wml; text/x-component htc; application/pkix-crl crl; image/png png; image/tiff tif tiff; image/vnd.wap.wbmp wbmp; image/x-icon ico; image/x-jng jng; image/x-ms-bmp bmp; image/svg+xml svg svgz; image/webp webp; application/java-archive jar war ear; application/mac-binhex40 hqx; application/msword doc; application/pdf pdf; application/postscript ps eps ai; application/rtf rtf; application/vnd.ms-excel xls; application/vnd.wap.wmlc wmlc; application/vnd.google-earth.kml+xml kml; application/vnd.google-earth.kmz kmz; application/x-7z-compressed 7z; application/x-cocoa cco; application/x-java-archive-diff jardiff; application/x-java-jnlp-file jnlp; application/x-makeself run; application/x-perl pl pm; application/x-pilot prc pdb; application/x-rar-compressed rar; application/x-redhat-package-manager rpm; application/x-sea sea; application/x-shockwave-flash swf; application/x-stuffit sit; application/x-tcl tcl tk; application/x-x509-ca-cert der pem crt; application/x-xpinstall xpi; application/xhtml+xml xhtml; application/zip zip; application/octet-stream bin exe dll; application/octet-stream deb; application/x-apple-diskimage dmg; application/octet-stream eot; application/octet-stream iso img; application/octet-stream msi msp msm; audio/midi mid midi kar; audio/mpeg mp3; audio/ogg ogg; audio/x-m4a m4a; audio/x-realaudio ra; video/3gpp 3gpp 3gp; video/mp4 mp4; video/mpeg mpeg mpg; video/quicktime mov; video/webm webm; video/x-flv flv; video/x-m4v m4v; video/x-mng mng; video/x-ms-asf asx asf; video/x-ms-wmv wmv; video/x-msvideo avi; application/x-openvpn-profile ovpn; } default_type application/octet-stream; sendfile on; #tcp_nopush on; #keepalive_timeout 0; keepalive_timeout 65; keepalive_requests 100000; upstream <servername>.<domainname>.ru { server xxx.xxx.xxx.xxx:443; } gzip on; gzip_types text/css text/javascript application/x-javascript text/plain text/xml text/x-component text/json application/octet-stream; gzip_min_length 500; gzip_disable msie6; proxy_next_upstream error timeout http_503; ########################### # http://<servername>.<domainname>.ru server { listen yyy.yyy.yyy.yyy:80; server_name <servername>.<domainname>.ru; rewrite ^/(.*)$ https://$server_name redirect; } ################################################# # https://<servername>.<domainname>.ru:443 # server { listen yyy.yyy.yyy.yyy:443 ssl; server_name <servername>.<domainname>.ru; ssl_certificate <domainname>.pem; ssl_certificate_key <domainname>.pem; error_log /big/nginx/<servername>.error_log; access_log /big/nginx/<servername>.access.log combined buffer=32k; location / { chunked_transfer_encoding on; proxy_connect_timeout 3; proxy_set_header Host <servername>.<domainname>.ru; proxy_send_timeout 90; proxy_read_timeout 90; proxy_pass https://<servername>.<domainname>.ru; } } 3. Логи настроены только на ошибки и на доступ. Ошибок нет. На доступ постараюсь выложить. На данный момент отрубили правило и оставили пока все во внутренней сети. 4. Просил включить компрессию (по аналогии с компрессией для правил TMG). Не помогло. |
Разработчик
Добавьте в конфиг nginx для модуля gzip:
Код: gzip_vary = on Возможно поможет, по умолчанию off, и в конфигах не указано его значение у Вас. Других подвохов не увидел. |
Сообщение от perestoronin
| Опции просмотра | |
