Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 24.11.2012, 22:23   #1
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
String literals must be enclosed in double quotes Try this:
qbr.value(strfmt('((%1 == "%2") || (%3 == "%4"))',
Старый 24.11.2012, 22:42   #2
Kent is offline
Kent
Yes, this is correct way. Whole hour looked at query and didn't sigth that nuance.
Thank You!
ax-erp: X++ Code to get the Ranges / Criteria from Query Blog bot DAX Blogs 0 12.06.2012 12:11
daxline: How to add empty ranges in query Blog bot DAX Blogs 0 28.06.2011 19:11
daxline: SysQuery::findOrCreateRange() - A better way to create dynamic query ranges Blog bot DAX Blogs 0 28.01.2011 23:14
jinx: Dynamics AX – Query-Ranges und Filtereinstellungen des Benutzers Blog bot DAX auf Deutsch 0 04.02.2010 00:05
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
Часовой пояс GMT +3, время: 08:42.
