Старый 08.02.2012, 21:12   #1
axdaily: More on CIL debugging
Источник: http://axdaily.blogspot.com/2012/02/...debugging.html
In the case you don't like debugging X++ code in Visual Studio there is a way to prevent code execution in CIL and to use the standard AX debugger instead.
This can be done in the Tools->Options form.
ssmantha: Debugging .NET code called from X++ code in AX 2012 Blog bot DAX Blogs 1 11.11.2011 15:50
X++: .NET Interop to X++ When X++ Runs as CIL Blog bot DAX Blogs 0 21.09.2011 05:12
axdaily: Debugging managed code in AX 2012 Blog bot DAX Blogs 0 14.05.2011 05:29
axdaily: X++ can be compiled to CIL in AX 2012 Blog bot DAX Blogs 0 23.04.2011 07:11
Microsoft Dynamics CRM Team Blog: Part 2: IE 8 Developer Tools and CRM 4 – Client Side Debugging Blog bot Dynamics CRM: Blogs 0 07.04.2009 08:05
Часовой пояс GMT +3, время: 09:00.
