Member
Джоб
X++: static void glibs(Args _args) { TmpAccountSum tmpAccountSum1, tmpAccountSum2; Counter i; FreeText text; Counter startTime; #Define.cycles(1000) ; startTime = WinAPI::getTickCount(); for (i = 0; i <= #cycles; i++) { tmpAccountSum1.clear(); tmpAccountSum2.clear(); text = int2str(i); tmpAccountSum1.AccountNum = strrep("0", 20 - strlen(text)) + text; tmpAccountSum2.AccountNum = strrep("0", 20 - strlen(text)) + text; tmpAccountSum1.Balance01 = 999999 * 888888; tmpAccountSum2.Balance01 = 999999 * 888888; tmpAccountSum1.Balance02 = 999999 * 888888; tmpAccountSum2.Balance02 = 999999 * 888888; tmpAccountSum1.Balance03 = 999999 * 888888; tmpAccountSum2.Balance03 = 999999 * 888888; tmpAccountSum1.Balance04 = 999999 * 888888; tmpAccountSum2.Balance04 = 999999 * 888888; tmpAccountSum1.Balance05 = 999999 * 888888; tmpAccountSum2.Balance05 = 999999 * 888888; tmpAccountSum1.Balance06 = 999999 * 888888; tmpAccountSum2.Balance06 = 999999 * 888888; tmpAccountSum1.Balance07 = 999999 * 888888; tmpAccountSum2.Balance07 = 999999 * 888888; tmpAccountSum1.Balance10 = 999999 * 888888; tmpAccountSum2.Balance10 = 999999 * 888888; tmpAccountSum1.TaxCode = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum2.TaxCode = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum1.CurrencyCode = "XXX"; tmpAccountSum2.CurrencyCode = "XXX"; tmpAccountSum1.Posting = 1; tmpAccountSum2.Posting = 1; tmpAccountSum1.Dimension[1] = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum2.Dimension[1] = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum1.Dimension[2] = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum2.Dimension[2] = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum1.Dimension[3] = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum2.Dimension[3] = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum1.OperationsTax = 1; tmpAccountSum2.OperationsTax = 1; tmpAccountSum1.TransDate = today(); tmpAccountSum2.TransDate = today(); tmpAccountSum1.Txt = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" + "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" + "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" + "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"; tmpAccountSum2.Txt = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" + "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" + "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" + "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"; tmpAccountSum1.SortDate = today(); tmpAccountSum2.SortDate = today(); tmpAccountSum1.Balance01Cur = 999999 * 888888; tmpAccountSum2.Balance01Cur = 999999 * 888888; tmpAccountSum1.Qty01 = 999999 * 888888; tmpAccountSum2.Qty01 = 999999 * 888888; tmpAccountSum1.Qty02 = 999999 * 888888; tmpAccountSum2.Qty02 = 999999 * 888888; tmpAccountSum1.Qty03 = 999999 * 888888; tmpAccountSum2.Qty03 = 999999 * 888888; tmpAccountSum1.Voucher = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum2.Voucher = "XXXXXXXXXXXXXXXXXXXX"; tmpAccountSum1.insert(); tmpAccountSum2.insert(); } info (strfmt("%1", (WinAPI::getTickCount() - startTime) / 1000)); startTime = WinAPI::getTickCount(); i = 0; while select tmpAccountSum1 join tmpAccountSum2 where tmpAccountSum1.AccountNum == tmpAccountSum2.AccountNum { text = tmpAccountSum1.Voucher + tmpAccountSum2.Voucher; i++; } info (strfmt("%1", i)); info (strfmt("%1", (WinAPI::getTickCount() - startTime) / 1000)); startTime = WinAPI::getTickCount(); i = 0; while select tmpAccountSum1 { while select tmpAccountSum2 where tmpAccountSum2.AccountNum == tmpAccountSum1.AccountNum { text = tmpAccountSum1.Voucher + tmpAccountSum2.Voucher; i++; } } info (strfmt("%1", i)); info (strfmt("%1", (WinAPI::getTickCount() - startTime) / 1000)); }
С уважением, glibs® |
За это сообщение автора поблагодарили: mazzy (5), sukhanchik (3), Logger (15). |
Member
Для тех кто не читает Х++. Остальные могут вместо этого просто прочитать код джоба
Для тех кто не понимает по Х++совски.
Эксперимент проводится на таблице TmpAccountSum, которую можно найти в АОТ в стандартной поставке. Это временная таблица. В ней есть несколько десятков полей различного вида (точнее, зазличных типов данных). Подробнее вы можете познакомиться с ней открыв АОТ. В начале джоба написан код, который создает два экземпляра этой таблицы и заполняет их откровенным хламом (левыми данными). Оба экземпляра заполняются абсолютно одинаковыми данными лишенными какого либо смысла. В этом нет никакой причины кроме лени и рационализма. Единственная цель которая пресдедовалась — чтобы все поля заполнить максимальным количеством символов, которые они могут вместить (чтобы каждая запись занимала как можно больше места на диске). Для показательности. И только одно поле я заполнил немного интеллектуальнее. TmpAccountSum.AccountNum. Оно содержит порядковый номер записи переведенный в целочисленное строковое значение и добивается до максимальной длинны поля лидирующими нулями. Такм образом TmpAccountSum.AccountNum содержит некий уникальный искусственно созданный ключ (на уровне структуры данных TmpAccountSum.AccountNum уникальным не является). В результате TmpAccountSum.AccountNum заполняется примерно так: 00000000000000000000 00000000000000000001 00000000000000000002 00000000000000000003 и т.д. Количество создаваемых строк задается в макросе #Define.cycles(1000) в конце списка определения переменных в джобе. Суть эксперимента В джобе написаны два блока кода. Они абсолютно равнозначны. В первом блоке оба экземпляра временных таблиц джоинятся друг к другу по полю AccountNum. Во втором блоке делается перебор записей в первом экземпляре в цикле и для каждой записи первого экземпляра перебираются все записи второго экземпляра, AccountNum которых равен AccountNum первого экземпляра. Короче, тот же джоин что и в первом случае, но реализованный через вложенный цикл. Поскольку в поле AccountNum данные искусственно записываются уникальные, то первой записи первого экземпляра временной таблицы соответствует первая запись второго экземпляра временной таблицы. И т.д. То есть в результате выборки данные не мультиплицируются. Количество строк в результате выборки будет равно количеству записей в каждой таблице. Сделано это специально, чтобы размер выборки был небольшим. Итак...
С уважением, glibs® Последний раз редактировалось sukhanchik; 15.12.2011 в 00:46. |
За это сообщение автора поблагодарили: sukhanchik (2). |
Member
Результаты эксперимента: скорость джоин vs вложенный цикл
На 1000 записей в каждом экземпляре временной раблицы
============================================= 0.28 - Времы вставки по 1000 записей в каждый из экземпляров временных таблиц 1001 - Количество выбранных записей в первой выборке 8.53 - Время выборки с джоином временных таблиц 1001 - Количество выбранных записей во второй выборке 0.05 - Время выборки с вложенным циклом вместо равнозначного первой выборке джоина временных таблиц На 2000 записей в каждом экземпляре временной раблицы (увеличиваем количество строк временной таблицы вдвое) ============================================================== 0.53 - время вставки возросло почти вдвое 2001 - записей стало пракически вдвое больше 33.11 - времы выборки с джоином увеличилось вчетверо 2001 - нечего комментировать 0.08 - время выборки с вложенным циклом увеличилось меньше чем вдвое Попробуем 4000 записей в каждом экземпляре временной раблицы (увеличиваем количество строк временной таблицы вдвое) ============================================================== 1.09 - опять чуть меньше чем вдвое 4001 - очень ожидаемо 136.34 - снова чуть больше чем вчетверо 4001 - нечего комментировать 0.17 - тоже чуть больше чем вдвое Первые выводы: Время вставки растет почти прямо пропорционально количеству записей. Время выборки с вложенным циклом также растет прямо пропорционально количеству записей во временных таблицах. Время выборки с джоином растет пропорционально приросту количества записей в квадрате. Складывается впетатление, что джоин тупо перебирает все записи первой таблицы и для каждой аписи перебирает все записи второй таблицы. А потом уже смотрит на условия джоина. Но это еще не все...
С уважением, glibs® Последний раз редактировалось glibs; 15.12.2011 в 01:46. |
Теги |
временная таблица, оптимизация, полезное, производительность |
Опции просмотра | |
