emeadaxsupport: Retail Store Connect: Item cannot be found in the collection corresponding to the requested name or ordinal
Источник: http://blogs.msdn.com/b/emeadaxsuppo...r-ordinal.aspx
============== Issue: Item cannot be found in the collection corresponding to the requested name or ordinal., table 'RBOSTAFFTABLE': 5637146104,0,0,0,0,0,0,0,0,0,0,,ceu,84374,,0,John,Doe,,1,30,0,0,0,40,0,Admin,4/13/2010 6:57:01 PM,John Evans,JohnE,0758441cBD8C3CE1,PoljiTh Cause: The issue is that the schema of the AxRetailPOS database if not matching the columns that is in the package file The reason is that the version of the POS is not matching the HQ application Example having R2 Refresh(5.0.1506.1032) in the HQ, but the POS.exe is R1 release (5.0.1506.130) Solution: Install a matching system with the same build Author: Kim Editor: Kim Date: 23. August 2011 Источник: http://blogs.msdn.com/b/emeadaxsuppo...r-ordinal.aspx
