Отчёты теперь загружаются всегда, ошибок пока нет, похоже помогло вот это:
Проблема при смене подразделений пользователей Но при открытии отчёта в логах выдаётся следующая ошибка: Цитата:
Event code: 3005
Event message: An unhandled exception has occurred. Event time: 25.03.2011 11:49:01 Event time (UTC): 25.03.2011 8:49:01 Event ID: 0e025fb136744cfcb049385d462ca4ea Event sequence: 135943 Event occurrence: 73 Event detail code: 0 Application information: Application domain: /LM/W3SVC/1/ROOT-1-129454645710894083 Trust level: Full Application Virtual Path: / Application Path: C:\inetpub\wwwroot\ Machine name: SMSK01CRM01 Process information: Process ID: 1076 Process name: w3wp.exe Account name: domain\crm Exception information: Exception type: WebException Exception message: The request failed with HTTP status 401: Unauthorized. Request information: Request URL: https://crm4.domain.ru:443/Reserved....49%3A01%202011 Request path: /Reserved.ReportViewerWebControl.axd User host address: 10.101.254.79 User: domain\username.username Is authenticated: True Authentication Type: Negotiate Thread account name: domain\crm Thread information: Thread ID: 11 Thread account name: domain\crm Is impersonating: True Stack trace: at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at Microsoft.SqlServer.ReportingServices2005.Execution.ReportExecutionService.GetExecutionInfo() at Microsoft.SqlServer.ReportingServices2005.Execution.RSExecutionConnection.GetExecutionInfo() at Microsoft.Reporting.WebForms.ServerReport.TouchSession() at Microsoft.Reporting.WebForms.SessionKeepAliveOperation.PerformOperation(NameValueCollection urlQuery, HttpResponse response) at Microsoft.Reporting.WebForms.HttpHandler.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) Custom event details: |
Теги |
sql 2008, отчеты |
Опции просмотра | |
