Старый 20.08.2010, 14:01   #1
Wamr is offline
Wamr
1,737 / 868 (32) +++++++
Записей в блоге: 7
вот к чему в конечном итоге приводит любовь к "хорошей идеи"
    while select
    sum(Qty), sum(costAmountPosted), sum(costAmountAdjustment) from InventTrans
    group by ItemId
    where
    (!itemId || InventTrans.ItemId == itemId)
            !dateFrom
                InventTrans.DatePhysical > dateFrom
                    isTime
                        InventTrans.DatePhysical == dateFrom &&
                            InventTrans.GM_DatePhysical > dateFrom
                                InventTrans.GM_DatePhysical == dateFrom &&
                                InventTrans.AX_TimePhysical >= timeFrom
            !dateTo
                InventTrans.DatePhysical < dateTo
                    isTime
                        InventTrans.DatePhysical == dateTo &&
                            InventTrans.GM_DatePhysical < dateTo
                                InventTrans.GM_DatePhysical == dateTo &&
                                InventTrans.AX_TimePhysical < timeTo
        InventTrans.StatusReceipt == StatusReceipt::Purchased ||
        InventTrans.StatusReceipt == StatusReceipt::Received ||
        InventTrans.StatusIssue == StatusIssue::Sold ||
        InventTrans.StatusIssue == StatusIssue::Deducted
    && InventTrans.TransType == InventTransType::Sales
    join salesTable group by GM_SalesOperationType where
    salesTable.SalesId == inventTrans.TransRefId
    join inventDim group by inventDimDefect where
    inventDim.inventDimId == inventTrans.inventDimId &&
    (!defect || inventDim.inventDimDefect == defect)
    exists join GM_CalcInventLocationOperational where
    dataAreaAdmin ||
    (!dataAreaAdmin && GM_CalcInventLocationOperational.InventLocationId == inventDim.InventLocationId)
    exists join GM_CalcInventLocationAdministrative where
            dataAreaAdmin &&
            GM_CalcInventLocationAdministrative.CalcInventLocation == GM_CalcInventLocation &&
            GM_CalcInventLocationAdministrative.InventLocationId == inventDim.InventLocationId
            !dataAreaAdmin &&
            GM_CalcInventLocationAdministrative.InventLocationId == GM_CalcInventLocationOperational.AdministrativeInventLocationId &&
За это сообщение автора поблагодарили: fed (5), Lemming (5), gl00mie (2).
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Rajdip's space: When using index (not using hint) in a select statement without 'GroupBy' or 'OrderBy' in what sequence do the records occur Blog bot DAX Blogs 0 20.04.2010 20:05
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
Fred Shen: Always use recId to know if a select statement returns a record Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 00:29.
