Старый 20.08.2010, 03:15   #1
Dianne Siebold: Generate a Report of Reports
Источник: http://blogs.msdn.com/b/dsiebold/arc...f-reports.aspx
If you have ever thought to yourself, "Gee, I sure wish I had a list of all the reports in my AX installation," then your wait is over.
Now you can use this handy report to generate a list all of the reports in your AX 2009 installation. After you import the XPO, you'll see a project called BookOfReportsV1. Within this project there's a report called BookOfReports and an output menu item called BookOfReports.
To run the report, just right-click on the report and select Open.
Many thanks to Jose Lorenzo at Microsoft for providing this code.
Dianne Siebold: Dynamics AX Goes Green Blog bot DAX Blogs 0 05.08.2009 10:05
Microsoft Dynamics CRM Team Blog: Including External Data in Microsoft Dynamics CRM 4.0 Reports Blog bot Dynamics CRM: Blogs 0 12.06.2009 04:31
Microsoft Dynamics CRM Team Blog: Auditing Report Execution using the ReportServer Database Blog bot Dynamics CRM: Blogs 0 19.11.2008 20:05
Dynamics AX: In the spot light: Dianne Siebold's WebLog Blog bot DAX Blogs 0 17.09.2008 20:05
Часовой пояс GMT +3, время: 01:43.
