Модератор
![]() На ошибку “An error occurred when opening Report Designer. A supported version of Visual Studio could not be found.“ я тоже нарвался ![]() Аналогичная проблема прослеживается с в NAV Team: Visual Studio 2010 and SSRS (RDLC) reports in NAV 2009 В Microsoft Dynamics AX 2009 System Requirements Сказано: Цитата:
Component
Reporting tools Additional requirement
We recommend downloading the Visual Studio hotfix available in Microsoft Knowledge Base article number 947173. In Visual Studio 2005, when you opened a SQL Server Reporting Services 2005 RDLC file, a DataSets panel was available to drag and drop fields onto the report design surface. In Visual Studio 2008, the DataSets panel is not available by default. This hotfix makes the DataSets panel available. Тема о проверенной совместимости (New Compatibility Testing Results - March 2010) Visual Studio 2010 и Dynamics AX 2009 вселяла надежду, но VS2010 больше подходит для работы с Enterprise Portal developer tools. Буду юзать Report Builder 3.0 Пост из блога о Visual Studio 2010 и Dynamics AX 2009 Visual Studio 2010 and .Net 4.0 Passed Compatibility Testing with Dynamics AX
This posting is provided "AS IS" with no warranties, and confers no rights. |
Теги |
ax2009, reporting services, visual studio |
