Старый 13.05.2010, 01:05   #1
paruvella: Displaying the Standard Ax report in EP pages of AX – Part – II
Источник: http://paruvella.spaces.live.com/Blo...4DB0!515.entry
In this example, we will see how we will pass the parameters to the Report Query object from EP pages.
We will display the Customer report in EP pages of Dynamics Ax, based on the filter condition of customer account.
For this example, I will continue with my previous article.
http://paruvella.spaces.live.com/blog/cns!F2EC589E221A4DB0!509.entry
For the class, PSReportRunFromEP add the following things.
New methods:
public CustAccount setCustAccount(CustAccount _custAccount)
    custAccount = _custAccount;
    return custAccount;
protected void initQuery()
//in this method, I am going to change the Query by adding filters to the Report Query
     report = new Report(reportName);       //reportName = “Cust”
    query = new Query(report.query());     // here I will get the Report Query def into query obj.
    query.dataSourceTable(tableNum(CustTable)).rangeField(fieldNum(CustTable, AccountNum)).value(custAccount);  //passing the value
Modify methods:
public static void reportToPDFFile(CustAccount _custAccount)
    PSReportRunFromEP reportRunFromEP = new PSReportRunFromEP();
    reportRunFromEP.setCustAccount(_custAccount);
    reportRunFromEP.initValue();
    reportRunFromEP.reportRun();
void initValue()
    //same lines from prev. article, just add the following line at the end
    this.initQuery();
void reportRun()
    …. //Same lines from prev. article
    reportRun.query(query);                                   //Uncomment this line from my prev. article
Make sure that above class is added in Proxies.
Need to update the Proxies definition from Tools àDevelopment Tools àWeb Development àProxies and click on the Generate button.
Now we will develop the required Web parts
Web Part –I
C# Code -- Code behind
using Microsoft.Dynamics.Framework.BusinessConnector.Session;
using ApplicationProxy = Microsoft.Dynamics.Portal.Application.Proxy;
using Proxy = Microsoft.Dynamics.Framework.BusinessConnector.Proxy;
public partial class EPCustReportHostl : System.Web.UI.UserControl
    private ISession AxSession
        get
            AxBaseWebPart webpart = AxBaseWebPart.GetWebpart(this);
            return webpart == null ? null : webpart.Session;
    protected void Page_Load(object sender, EventArgs e)
    protected void ReportButton_Click(object sender, EventArgs e)
        //calling the proxy method for generating the report into PDF file and the same report we are displaying in EP
        Microsoft.Dynamics.Portal.Application.Proxy.PSReportRunFromEP.reportToPDFFile(this.AxSession.AxaptaAdapter, TextBoxFilterCustAccount.Text);
AxUrlMenuItem url = new AxUrlMenuItem("EPCustomerReport"); // This URL is for displaying the report in PDF file
HttpContext.Current.ApplicationInstance.CompleteRequest();
        Response.Redirect(url.Url.OriginalString, false);
Add this web part to the new page (EPCustomerReportHost.aspx), import the URL definition in to the Ax AOT and add this URL to web menus of Sales module.
Web Part –II
Nothing to design here, just add the following code in the Page_Load() method of web part
public partial class EPCustomerReportsl : System.Web.UI.UserControl
        FileInfo fi = null;
        fi = new FileInfo("D:\\Customers.pdf");
        if (fi.Exists)
            Response.Clear();
            Response.ContentType = "application/pdf";
            Response.Flush();
            Response.WriteFile(fi.FullName);
            Response.End();
Add this web part to the new page (EPCustomerReport.aspx), import the URL definition in to the Ax AOT.  We will refer same web menu item URL in first web part of button click event.
Now open the page EPCustomerReportHost from the Sales module of EP and page will be displayed as follows.
Select the customer and click on Report button on the same page.  Customer 2003 details will be displayed in next page as a PDF file.
This way we can pass the parameters from EP pages to the standard reports.
i.e. exactly, how we have the parameters for the reports in Ax client, same behavior we can bring for the EP reports also, and we can generate similar reports from EP as well.
paruvella: Displaying the Standard Ax report in EP pages of AX Blog bot DAX Blogs 0 04.05.2010 18:05
paruvella: Displaying SSRS report in Ax-EP page Blog bot DAX Blogs 0 02.02.2010 21:05
paruvella: Displaying the employee images on the EP pages of Dynamics Ax Blog bot DAX Blogs 0 15.12.2009 23:05
paruvella: Different styles (*.css) for our EP pages of Ax 2009 Blog bot DAX Blogs 0 12.11.2009 21:05
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 18:42.
