Старый 16.03.2010, 17:36   #1
slivka_83 is offline
slivka_83
Консультант-джедай
Аватар для slivka_83
1,683 / 374 (16) ++++++
Попробуйте включить логи для почты http://mmcrm.ru/?p=199?
Экстремал и буду экстремать!
Блога
Старый 17.03.2010, 09:55   #2
ka3ax is offline
ka3ax
Сообщение от slivka_83 Посмотреть сообщение
Логи включил. И вот что в них пишется "
03/17/2010 09:37:38 : #62269 - Checking for outgoing e-mail messages to process for SMTP: http://sarpag6/First.
03/17/2010 09:37:38 : #29426 - There are no e-mail messages to process in mailbox SMTP: http://sarpag6/First.
03/17/2010 09:37:38 : #60687 - The thread that is processing mailbox SMTP: http://sarpag6/First is shutting down as requested.
03/17/2010 09:38:38 : #62269 - Checking for outgoing e-mail messages to process for SMTP: http://sarpag6/First.
03/17/2010 09:38:38 : #15393 - Validating the outgoing e-mail message with subject "Логи CRM:0001025" from d.munchak@xxx.ru to denis@yyy.ru for SMTP: http://sarpag6/First.
03/17/2010 09:38:38 : #1866 - Checking the e-mail message with subject "Логи CRM:0001025" in mailbox SMTP: http://sarpag6/First for delivery to 123.xxx.ru.
03/17/2010 09:38:43 : #61042 - An error occurred while processing the outgoing e-mail message with subject "Логи CRM:0001025" for SMTP: http://sarpag6/First for delivery through 123.xxx.ru. System.Net.Mail.SmtpFailedRecipientException: Почтовый ящик недоступен. Ответ сервера: 5.7.1 Unable to relay
в System.Net.Mail.SmtpTransport.SendMail(MailAddress sender, MailAddressCollection recipients, String deliveryNotify, SmtpFailedRecipientException& exception)
в System.Net.Mail.SmtpClient.Send(MailMessage message)
в Microsoft.Crm.Tools.Email.Providers.SmtpPollingSendEmailProvider.ProcessMessageInternal(email emailMessage)
в Microsoft.Crm.Tools.Email.Providers.CrmPollingSendEmailProvider.Run()
03/17/2010 09:38:43 : #62269 - Checking for outgoing e-mail messages to process for SMTP: http://sarpag6/First.
03/17/2010 09:38:43 : #29426 - There are no e-mail messages to process in mailbox SMTP: http://sarpag6/First.
03/17/2010 09:38:43 : #60687 - The thread that is processing mailbox SMTP: http://sarpag6/First is shutting down as requested.
03/17/2010 09:39:38 : #62269 - Checking for outgoing e-mail messages to process for SMTP: http://sarpag6/First.
03/17/2010 09:39:38 : #29426 - There are no e-mail messages to process in mailbox SMTP: http://sarpag6/First.
03/17/2010 09:39:38 : #60687 - The thread that is processing mailbox SMTP: http://sarpag6/First is shutting down as requested.
03/17/2010 09:40:38 : #62269 - Checking for outgoing e-mail messages to process for SMTP: http://sarpag6/First.
03/17/2010 09:40:38 : #29426 - There are no e-mail messages to process in mailbox SMTP: http://sarpag6/First.
03/17/2010 09:40:38 : #60687 - The thread that is processing mailbox SMTP: http://sarpag6/First is shutting down as requested."
я так понимаю ошибка вот здесь "System.Net.Mail.SmtpFailedRecipientException: Почтовый ящик недоступен. Ответ сервера: 5.7.1 Unable to relay". Вот почему он пишет что ящик не доступен?
Проблема MSCRM 3.0. Отображение "Все сообщения электронной почты" Gogus Dynamics CRM: Администрирование 2 19.02.2010 13:42
Проблема с действиями сервиса(CRM 4.0) Archon Dynamics CRM: Функционал 6 08.07.2009 14:33
Проблема при создании мероприятия ShurikEv Dynamics CRM: Функционал 2 03.11.2008 18:26
Проблема с отслеживание электронной почты demonik Dynamics CRM: Администрирование 25 17.03.2008 18:03
Проблема с отправкой почты из CRM Zus Dynamics CRM: Администрирование 1 03.04.2007 07:37
Часовой пояс GMT +3, время: 19:34.
