crmdude: Create Deployment Administrator via Database
Источник: http://crmdude.wordpress.com/2010/02...-via-database/
============== Recently I had to make some changes to a CRM server and needed to run the Deployment Manager tool. However, I had performed the installation with an account that had elevated security rights to my own one. In such a situation, proper protocol and best-practice administration dictates that one asks the appropriate individual to simply create a new Deployment Administrator. However, if you wanted to circumvent the rules, here’s how: 1. Open your user record in Microsoft CRM and copy your user id (Ctrl + N), 2. Open Microsoft SQL Server Management Studio, right click on the MSCRM_CONFIG database and select ‘New Query’, 3. Run the following query to work out your Id and UserId from the SystemUserOrganisations table: select Id, UserId from SystemUserOrganizations where CrmUserId = 'f01af5f8-959e-de11-9f0f-00188bfcb0e0' // replace with your CrmUserId 4. Now use the returned Id and UserId and insert into the SystemUserRoles table: insert into SystemUserRoles ([Id] ,[SecurityRoleId] ,[SystemUserId] ,[IsDeleted]) values ('F51AF5F8-959E-DE11-9F0F-00188BFCB0E0' // replace with your ID returned above ,'19cfbc8d-77ed-459e-9909-1bf1cc1b0430' ,'F31AF5F8-959E-DE11-9F0F-00188BFCB0E0' // replace with your UserId returned above ,'False') You should be able to access the Deployment Manager now. Tagged: database, deployment, unsupported ![]() Источник: http://crmdude.wordpress.com/2010/02...-via-database/
Проще нормально добавить дополнительного администратора через консоль.
http://fixrm.wordpress.com, снятие/наведение порчи. Быстро, дорого, гарантия. ![]() MS Certified Dirty Magic Professional
