Старый 25.11.2009, 12:10   #29
Soulcar is offline
Soulcar
Аватар для Soulcar
129 / 10 (1) +
Подробные ошибки включите.
А они были включены(я проверял)...
Вот что я вытянул через Log Viewer:
Error: Exception has been thrown by the target of an invocation.
Error Number: 0x80048298
Error Message: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded.
Error Details: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded.
Source File: Not available
Line Number: Not available
Request URL: http://xxxxxxxxxxxxxxxxxxxx/crmrepor...tproperty.aspx
Stack Trace Info: [SoapException: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded. ---> The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded.]
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Microsoft.Crm.ReportingServices2005.ReportingService2005.CreateReport(String Report, String Parent, Boolean Overwrite, Byte[] Definition, Property[] Properties)
at Microsoft.Crm.Reporting.ReportServer.UploadReport(String path, Byte[] reportDefinition, String name, String description)
[CrmReportingException: The report definition is not valid. Details: The report definition has an invalid target namespace 'http://schemas.microsoft.com/sqlserver/reporting/2008/01/reportdefinition' which cannot be upgraded.]
at Microsoft.Crm.Reporting.ReportServer.UploadReport(SRSReport report, String reportId, String name, String description)
at Microsoft.Crm.ObjectModel.ReportService.UploadSRSReport(Guid id, String name, String description, SRSReport srsReport, ExecutionContext context)
at Microsoft.Crm.ObjectModel.ReportService.CreateInternal(IBusinessEntity entity, Boolean isScheduledReport, ExecutionContext context)
[TargetInvocationException: Exception has been thrown by the target of an invocation.]
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Web.Services.Protocols.LogicalMethodInfo.Invoke(Object target, Object[] values)
at Microsoft.Crm.Extensibility.InternalOperationPlugin.Execute(IPluginExecutionContext context)
at Microsoft.Crm.Extensibility.PluginStep.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request)
at Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal()
at Microsoft.Crm.Application.Platform.ServiceCommands.CreateCommand.Execute()
at Microsoft.Crm.Application.Platform.Report.Create(Boolean performDuplicateCheck)
at Microsoft.Crm.Application.Forms.AppForm.SaveEntity(EntityProxy entity, FormEventId eventType, String redirectPath, Boolean performDuplicateCheck)
Рассылка отчетов по электронной почте zhenek Dynamics CRM: Функционал 11 11.09.2009 10:07
Сбой при запуске отчетов с сервера CRM xmarina Dynamics CRM: Администрирование 5 03.09.2009 14:46
Ошибка при создании отчётов! moskalevas Dynamics CRM: Функционал 13 23.07.2009 14:14
Проблема с публикацией отчетов - не работает "Сделать отчет доступным для организации" serjio72 Dynamics CRM: Администрирование 8 16.07.2009 18:11
Не работает модуль отчетов Maxoon Dynamics CRM: Администрирование 25 03.03.2009 12:53
Часовой пояс GMT +3, время: 14:48.
