Старый 28.10.2009, 13:38   #1
raz is offline
raz
NavAx
Аватар для raz
NavAx Club
1,499 / 1097 (39) ++++++++
    Query q;
    QueryBuildDataSource qbdsCustInvoiceJour;
    QueryBuildDataSource qbdsCustInvoiceTrans;
    QueryBuildDataSource qbdsInventTrans;
    QueryBuildRange      range;
    Str600               value;
    q = new Query();
    qbdsCustInvoiceJour = q.addDataSource(tableNum(CustInvoiceJour), "CJTable");
    qbdsCustInvoiceJour.addSelectionField(fieldNum(CustInvoiceJour, InvoiceAccount));
    qbdsCustInvoiceJour.addSelectionField(fieldNum(CustInvoiceJour, InvoiceId));
    qbdsCustInvoiceJour.addSelectionField(fieldNum(CustInvoiceJour, SalesId));
    range = qbdsCustInvoiceJour.addRange(fieldNum(CustInvoiceJour, InvoiceAccount));
    range.value("39");
    qbdsCustInvoiceTrans= qbdsCustInvoiceJour.addDataSource(tableNum(CustInvoiceTrans));
    qbdsCustInvoiceTrans.addLink(fieldNum(CustInvoiceJour, InvoiceId),fieldNum(CustInvoiceTrans, InvoiceId));
    qbdsCustInvoiceTrans.addLink(fieldNum(CustInvoiceJour, SalesId), fieldNum(CustInvoiceTrans, SalesId));
    qbdsCustInvoiceTrans.addLink(fieldNum(CustInvoiceJour, InvoiceDate), fieldNum(CustInvoiceTrans, InvoiceDate));
    qbdsCustInvoiceTrans.addLink(fieldNum(CustInvoiceJour, numberSequenceGroup), fieldNum(CustInvoiceTrans, numberSequenceGroup));
    qbdsInventTrans = qbdsCustInvoiceTrans.addDataSource(tableNum(InventTrans),"ITTable");
    qbdsInventTrans.addLink(fieldNum(qbdsCustInvoiceTrans, InventTransId),fieldNum(InventTrans, InventTransId));
    qbdsInventTrans.addLink(fieldNum(qbdsCustInvoiceTrans, InvoiceId),fieldNum(InventTrans, InvoiceId));
    qbdsInventTrans.addLink(fieldNum(qbdsCustInvoiceTrans, InvoiceDate),fieldNum(InventTrans, DateFinancial));
    qbdsInventTrans.addSelectionField(fieldNum(InventTrans, RecId));
За это сообщение автора поблагодарили: Silphidae (1).
связь таблиц
InventTransIdReturn и Закрытие склада DenisS DAX: Программирование 15 03.12.2008 09:02
Достаточно ли изменить дату в таблицах inventTrans, inventTransPosting, VendPackingSlipJour? DmitryS DAX: Программирование 3 18.09.2008 14:37
Как правильно достучаться из InventTrans до даты накладыной NJD DAX: Программирование 6 22.07.2005 20:52
Связь таблиц InventTrans и PurchLine Pustik DAX: Программирование 2 25.11.2004 12:23
Ошибка при связывании InventTrans и InventJournaTable LCh DAX: Программирование 2 30.05.2004 15:22
Часовой пояс GMT +3, время: 10:27.
