Старый 22.07.2009, 16:05   #1
axaptafreak: Running Dynamics AX 2009 on Windows 7 using Windows Virtual XP
Источник: http://axaptafreak.blogspot.com/2009...windows-7.html
One of the new features in Windows 7 is that it contains a new version of Windows Virtual PC which can be used to publish applications from the virtual guest system to the host system.
To showcase what can be done with published applications on Windows Virtual PC, I was trying to install AX 2009 on the Virtual XP guest and to run it afterwards as a published application on my Windows 7 RC host system.
First, you have to get the Windows Virtual PC Beta installer and Windows XP Mode Beta from here: http://www.microsoft.com/windows/vir.../download.aspx
After installing everything, you will be able to start your Windows XP guest system and start installing the necessary components.
I will not go too much into detail about the installation steps (as this is just a showcase), so here are the necessary steps:
  • Install SQL Server 2008
  • Install Dynamics AX 2009 (AOS, Application Files, Client)
Right now you might think: "Stop! How could you install AX 2009 on the virtual Windows XP guest, it is not joined to a domain?"
Well, that was the really tricky part and as said before, I won't go into detail and just tell you: it was really hard but I managed to install it.
After everything was installed, AX is shown in the Windows Start Menu under Virtual Windows XP applications:
Now, you can start the virtual AX application and work with it. I imported some demo data which was located on my host machine into the virtual AX application.
As the new Windows Virtual PC is still in Beta, I have to say that although everything works smoothly, sometimes the Virtual application window disappears and you have to restart it from the start menu. After some time, the original window may appear again.
This is how AX 2009 looks like running in a virtual windows XP:
Helmut Wimmer
Старый 23.07.2009, 11:01   #2
Poleax is offline
Poleax
Модератор
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Интересно, а смысл ставить Dynamics AX 2009 на Virtual ( Windows XP Mode Beta ) на Windows 7 Ax 2009 и так не плохо работает.
Конечно это может пригодится для установки Axapta 3.0 ;-)
+ доп. материалы, как разворачивать XP Mode:
http://komatozo.blogspot.com/2009/06...7-xp-mode.html
http://ru.intel.com/business/communi...&showentry=796
Старый 23.07.2009, 11:40   #3
ax3.0 тоже неплохо работает в windows 7
Старый 24.07.2009, 11:20   #4
Poleax is offline
Poleax
Модератор
Аватар для Poleax
Записей в блоге: 34
Режим совместимости используется для ax 3.0?
virtual pc, windows 7
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
jinx: Microsoft Dynamics AX 2009, Windows Server 2008 und SQL Server 2008 Blog bot DAX auf Deutsch 0 12.10.2008 20:10
Часовой пояс GMT +3, время: 23:16.
