Member
You can use compare layers utility. This function is available in import dialog. Compare your USR with .XPO there. There you can open objects from the project from your USR and from .XPO in separate windows. For fields, field groups and groups on forms and reports it is convenient to use drag-&-drop from .XPO to your USR.
С уважением, glibs® |
За это сообщение автора поблагодарили: Hugon (1). |
