#21 |
Чайный пьяница
Подчистил код плагина. Попробуйте это:
Код: using System;
using System.Collections.Generic;
using Microsoft.Win32;
using Microsoft.Crm.Sdk.Query;
// Microsoft Dynamics CRM namespaces
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Crm.SdkTypeProxy.Metadata;
using System.Text;
namespace Crm.Plugins
public class MyPlugin : IPlugin
private string _secureInformation;
private string _unsecureInformation;
public MyPlugin(string unsecureInfo, string secureInfo)
_secureInformation = secureInfo;
_unsecureInformation = unsecureInfo;
public void Execute(IPluginExecutionContext context)
DynamicEntity entity = null;
if (context.InputParameters.Properties.Contains(ParameterName.Target) && context.InputParameters.Properties[ParameterName.Target] is DynamicEntity)
entity = (DynamicEntity)context.InputParameters.Properties[ParameterName.Target];
else
return;
try
ICrmService crmService = context.CreateCrmService(true);
decimal sum = ((CrmMoney)entity.Properties["new_esum"]).Value;
String new_productname = "";
if (entity.Properties.Contains("productid"))
ColumnSet cs = new ColumnSet();
Lookup regarding = (Lookup)entity.Properties["productid"];
cs.Attributes.Add("name");
product _product = (product)crmService.Retrieve(EntityName.product.ToString(), regarding.Value, cs);
if (_product == null || _product.name == null)
return;
else
new_productname = _product.name;
QueryByAttribute query = new QueryByAttribute();
query.ColumnSet = new AllColumns();
query.EntityName = EntityName.productpricelevel.ToString();
query.Attributes = new string[] { "productidname" };
query.Values = new string[] { new_productname };
BusinessEntityCollection retrieved = crmService.RetrieveMultiple(query);
foreach (DynamicEntity product in retrieved.BusinessEntities)
product["amount"] = new CrmDecimal(sum);
crmService.Update(product);
catch (System.Web.Services.Protocols.SoapException ex)
throw new InvalidPluginExecutionException(String.Format("An error occurred in the {0} plug-in.", this.GetType().ToString()), ex);
#22 |
Спасибо!!
Пока не изменилось ничего.. "для отладки - необходимо атачиться к w3p процессу." А это как? (стыдно, но правда не знаю.. )
#23 |
Чайный пьяница
Что говорит плагин регистратор при попытке регистрации?
Эмо разработчик, сначала пишу код, потом плачу над его несовершенством. Подписывайтесь на мой блог, twitter и YouTube канал. Пользуйтесь моим Ultimate Workflow Toolkit Последний раз редактировалось a33ik; 08.05.2009 в 12:50. |
#24 |
В Plagin Registration Tool нажимаю Register -> Register New Assembly Когда выбираю файл EditPriceList.dll (я его из папки Debug беру..в Release он тоже есть и еще там лежит файл key.snk.. Так и надо? ) Выскакивает ошибка "Unable to load PLugin Assembly" и текст ![]() Unhandled Exception: System.Runtime.Serialization.SerializationException: Тип "PluginRegistrationTool.CrmOrganization" в сборке "PluginRegistration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null" не помечен как сериализуемый. Server stack trace: в System.Runtime.Serialization.FormatterServices.InternalGetSerializableMembers(RuntimeType type) в System.Runtime.Serialization.FormatterServices.GetSerializableMembers(Type type, StreamingContext context) в System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitMemberInfo() в System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitSerialize(Type objectType, ISurrogateSelector surrogateSelector, StreamingContext context, SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter) в System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.Serialize(Type objectType, ISurrogateSelector surrogateSelector, StreamingContext context, SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter) в System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Write(WriteObjectInfo objectInfo, NameInfo memberNameInfo, NameInfo typeNameInfo) в System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Serialize(Object graph, Header[] inHeaders, __BinaryWriter serWriter, Boolean fCheck) в System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(Stream serializationStream, Object graph, Header[] headers, Boolean fCheck) в System.Runtime.Remoting.Channels.CrossAppDomainSerializer.SerializeMessageParts(ArrayList argsToSerialize) в System.Runtime.Remoting.Messaging.SmuggledMethodReturnMessage..ctor(IMethodReturnMessage mrm) в System.Runtime.Remoting.Messaging.SmuggledMethodReturnMessage.SmuggleIfPossible(IMessage msg) в System.Runtime.Remoting.Channels.CrossAppDomainSink.DoDispatch(Byte[] reqStmBuff, SmuggledMethodCallMessage smuggledMcm, SmuggledMethodReturnMessage& smuggledMrm) в System.Runtime.Remoting.Channels.CrossAppDomainSink.DoTransitionDispatchCallback(Object[] args) Exception rethrown at [0]: в System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) в System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) в PluginRegistrationTool.AssemblyReader.RetrievePluginsFromAssembly(String path) в PluginRegistrationTool.RegistrationHelper.RetrievePluginsFromAssembly(String pathToAssembly) в PluginRegistrationTool.PluginRegistrationForm.btnLoadAssembly_Click(Object sender, EventArgs e) |
#25 |
Чайный пьяница
Очень странно. За годичную практику такого не было у меня.
Ещё такой вопрос. Под каким фреймворком собираете плагин? Нужно под 2.0. Гугл на вопрос по такой ошибке мне ничего не сказал...
#26 |
Я не знаю что значит "Под каким фреймворком собираете плагин". Но на моем компе , где я пытаюсь соорудить plugin , установлены Microsoft .NET Compact Framework 1.0 Developer Microsoft .NET Compact Framework 2.0 Microsoft .NET Framework 3.5 SP1 А это не может быть из-за того что я работаю в Microsoft Visual C# 2008 Express Edition? |
#27 |
Чайный пьяница
При создании плагина - необходимо выбрать версию фреймворка под который он будет писаться. Посмотрите скриншот (должен быть 2.0).
| За это сообщение автора поблагодарили: Elka (1). | |
#28 |
Ой, спасибо большое.. У меня вообще нет возможности выбора фреймворка. Наверно из-за этого все беды...Попробую найти и установить нормальную Visual Studio |
#29 |
Добрый день! После регистрации плагина, создаю в crm продукт для возможной сделки. При сохранении возникает ошибка :"Unable to cast object of type 'Microsoft.Crm.SdkTypeProxy.productpricelevel' to type 'Microsoft.Crm.Sdk.DynamicEntity'".
В плагине так: query.EntityName = EntityName.productpricelevel.ToString(); Не знаю как исправить .. Помогите, пожалуйста.. |
#30 |
Чайный пьяница
Сообщение от Elka
#31 |
Спасибо Вам большое !!Вот код: using System; using System.Collections.Generic; using Microsoft.Win32; using Microsoft.Crm.Sdk.Query; // Microsoft Dynamics CRM namespaces using Microsoft.Crm.Sdk; using Microsoft.Crm.SdkTypeProxy; using Microsoft.Crm.SdkTypeProxy.Metadata; using System.Text; namespace Crm.Plugins { publicclassMyPlugin : IPlugin { privatestring _secureInformation; privatestring _unsecureInformation; public MyPlugin(string unsecureInfo, string secureInfo) { _secureInformation = secureInfo; _unsecureInformation = unsecureInfo; } publicvoid Execute(IPluginExecutionContext context) { DynamicEntity entity = null; if (context.InputParameters.Properties.Contains(ParameterName.Target) && context.InputParameters.Properties[ParameterName.Target] isDynamicEntity) { entity = (DynamicEntity)context.InputParameters.Properties[ParameterName.Target]; } else { return; } try { ICrmService crmService = context.CreateCrmService(true); decimal sum = ((CrmMoney)entity.Properties["new_esum"]).Value; String new_productname = ""; if (entity.Properties.Contains("productid")) { ColumnSet cs = newColumnSet(); Lookup regarding = (Lookup)entity.Properties["productid"]; cs.Attributes.Add("name"); product _product = (product)crmService.Retrieve(EntityName.product.ToString(), regarding.Value, cs); if (_product == null || _product.name == null) { return; } else { new_productname = _product.name; } } QueryByAttribute query = newQueryByAttribute(); query.ColumnSet = newAllColumns(); query.EntityName = EntityName.productpricelevel.ToString(); query.Attributes = newstring[] { "productidname" }; query.Values = newstring[] { new_productname }; BusinessEntityCollection retrieved = crmService.RetrieveMultiple(query); foreach (DynamicEntity product in retrieved.BusinessEntities) { product["amount"] = newCrmDecimal(sum); crmService.Update(product); } } catch (System.Web.Services.Protocols.SoapException ex) { thrownewInvalidPluginExecutionException(String.Format("An error occurred in the {0} plug-in.", this.GetType().ToString()), ex); } } } } |
#32 |
Чайный пьяница
Исправьте код
Код: foreach (DynamicEntity product in retrieved.BusinessEntities)
}Код: foreach (productpricelevel product in retrieved.BusinessEntities)
product.amount = new CrmDecimal(sum);
#33 |
Ругается на new CrmDecimal(sum) "cannot implicity convert type 'Microsoft.Crm.Sdk.CrmDecimal' to 'Microsoft.Crm.Sdk.CrmMoney"
#34 |
Чайный пьяница
product.amount = new CrmMoney(sum);
#35 |
спасибо.. можно еще вопрос..(надеюсь последний..) Я заново скомпилировала.. В Plugin Registration Tool все отключила (unregister) и заново зарегистрировала плагин.. Однако на сервере s-crm (C:\Program Files\Microsoft Dynamics CRM\Server\bin\assembly) файлы .dll .pdb руками заменить на новые не получается ( их ведь надо заменить?)А в crm ошибка "Не удалось загрузить сборку подключаемого модуля"
#36 |
Чайный пьяница
Сообщение от Elka
спасибо.. можно еще вопрос..(надеюсь последний..) Я заново скомпилировала.. В Plugin Registration Tool все отключила (unregister) и заново зарегистрировала плагин.. Однако на сервере s-crm (C:\Program Files\Microsoft Dynamics CRM\Server\bin\assembly) файлы .dll .pdb руками заменить на новые не получается ( их ведь надо заменить?)А в crm ошибка "Не удалось загрузить сборку подключаемого модуля" ![]()
#37 |
Ура! Все работает!!! Спасибо большое!!!!!!
#38 |
Чайный пьяница
Вот и славненько.
*чухает голову и думает может в тренеры податься )
#39 |
Спасибо за детальное об'яснение этой темы.
Все стало значительно понятней, повторил все действия здесь описаные, скопировал код с поста и удалил всьо в методе Execute. Плугин регистрируется, но выполнятся не хочет пишет немогу загрузить асемблю ... В ивент вьювере - пусто, можно гдето логи какието найти или продебажить ? И еще одно - при регистрации прошу положить либу на диск, но не могу найти куда оно ее кладет ... ЦРМ стоит в папке D:\CRM4 - может здесь собака порылась ? Последний раз редактировалось Vuhasty; 15.05.2009 в 14:05. |
#40 |
Чайный пьяница
Сообщение от Vuhasty
| Теги |
| c#, plugin, pluginregistrationtool, регистрация |
