Solutions Monkey: AX Custom bound fields
Источник: http://blogs.msdn.com/solutions/arch...nd-fields.aspx
============== A new code sample demonstrating the flexibility to customize the boundfields in Microsoft Dynamics AX 2009 EP is released in http://code.msdn.microsoft.com/axcodesamples. Here is the link directly to the sample download file. To try out these samples, download this zip file and follow the instructions given in readme.txt file http://code.msdn.microsoft.com/Proje...ownloadId=5497 EP comes with a rich set of bound fields. This code sample demonstrates how to extend and add bound fields in EP for specific user interface requirements. This sample contains three types of bound fields:
NOTE : These are code samples are not intended for production use as is. You should use them as samples and build your own solutions and test it before using it in production system. These sample bound fields do not work with BoundField designer in VS. You should work in the markup directly to use these boundfields or make the code deal with the boundfield designer. ============== Источник: http://blogs.msdn.com/solutions/arch...nd-fields.aspx
