Старый 07.04.2009, 11:08   #1
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Lightbulb
Сообщение от O_Chiner Посмотреть сообщение
Будьте добры!
Вот такой код:
Код:
function GetBUId(userid)
	if (userid == null)
		return null;
	var xmlhttp = new ActiveXObject("Msxml2.XMLHTTP");
	xmlhttp.open("POST", "/mscrmservices/2007/crmservice.asmx", false);
	xmlhttp.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
	xmlhttp.setRequestHeader("SOAPAction", "http://schemas.microsoft.com/crm/2007/WebServices/Fetch");
	var xml = "<?xml version='1.0' encoding='utf-8'?>"+
	"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
	" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
	" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
	GenerateAuthenticationHeader() +
	" <soap:Body>" +
	"<Fetch xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
	"<fetchXml> "+
	"&lt;fetch mapping='logical'&gt; " +
	"&lt;entity name='systemuser'&gt; " +
	"&lt;attribute name='businessunitid' /&gt; " +
	"&lt;filter type='and'&gt; " +
	"&lt;condition attribute='systemuserid' operator='eq' value='" + userid +"'/&gt; " +
	"&lt;/filter&gt; " +
	"&lt;/entity&gt; " +
	"&lt;/fetch&gt;"+
	"</fetchXml>"+
	"</Fetch>"+
	"</soap:Body>"+
	"</soap:Envelope>";
	xmlhttp.setRequestHeader("Content-Length", xml.length);
	xmlhttp.send(xml);
	var resultSet = new String(xmlhttp.responseXml.text);
	resultSet.replace('&lt;','<');
	resultSet.replace('&gt;','>');
	var xmlDoc = new ActiveXObject("Microsoft.XMLDOM");
	xmlDoc.async=false;
	xmlDoc.loadXML(resultSet);
	var lookupitem = new Object();
	lookupitem.typename = "businessunit";
	lookupitem.id = xmlDoc.selectSingleNode("//resultset/result/businessunitid").nodeValue;
	lookupitem.name = xmlDoc.selectSingleNode("//resultset/result/businessunitid").attributes.getNamedItem("name").text;
	retutn lookupItem;
if (crmForm.all.ownerid.DataValue != null
    && crmForm.all.ownerid.DataValue.length != 0
    && crmForm.all.ownerid[0] != null)
	var lookupData = new Array();
	lookupData[0] = GetBUId(crmForm.all.ownerid[0].id);
	crmForm.all.new_businessunitid.DataValue = lookupData;
Чтобы не забыть напишу, что у пользователя должны быть права на Assign To к сущности BusinessUnit иначе даже такое присвоение никакого результата не даст. Уже сталкивался. Удачи.
За это сообщение автора поблагодарили: O_Chiner (1).
Как программно задавать обязательность поля на форме при заполнении? Bakai Madybaev Dynamics CRM: Функционал 6 10.10.2008 11:46
Заблокировать все поля на форме. IgorF Dynamics CRM: Разработка 12 07.04.2008 18:28
Как по названию поля определить название таблицы? Alexey-IT Dynamics CRM: Функционал 8 25.06.2007 13:06
Не отображаються закладки "Продажа" и "Маркетинг" pkost Dynamics CRM: Администрирование 1 31.10.2006 20:30
Часовой пояс GMT +3, время: 10:25.
