#21 |
Код: var invite4 = GetAttributeValueFromID('new_date_protocol', crmForm.all.new_protocolsfordate.DataValue[0].id, 'new_invite4');
crmForm.all.new_invite.DataValue=invite4
function GetAttributeValueFromID(sEntityName, GUID, sAttributeName)
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "";
xml = xml+"<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entityName>"+sEntityName+"</entityName>"+
"<id>"+GUID+"</id>"+
"<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+
"<q1:Attributes>"+
"<q1:Attribute>"+sAttributeName+"</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
var result = resultXml.selectSingleNode("//q1:" + sAttributeName).nodeTypedValue;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
result = " ";
// Display the retrieved value.
else
alert('test')
return result;
}Последний раз редактировалось vital.mih; 01.04.2009 в 07:59. |
#22 |
ну что нет ни у кого идей??
#23 |
Чайный пьяница
Это только идеи, которые не могу проверить на практике, потому что в отпуске с ноутом на коленях
.Итак: 1. Стоит всё-таки везде где надо ставить ; В вашем случае это строка 3 - crmForm.all.new_invite.DataValue=invite4; 2. Перед присвоением - поставьте alert(invite4); и убедитесь, что возвращается корректное значение. 3. Убедитесь, что поле new_invite вынесено на форму и желательно таки указать его тип, чтобы знать с чем имеем дело. 4. Перед выполнением поиска желательно вставить проверку, что crmForm.all.new_protocolsfordate.DataValue != null &&crmForm.all.new_protocolsfordate.DataValue.length != 0 Пробуйте. Если опять не заработает - есди дождётесь меня из отпуска и Вам не помогут - постараюсь помочь.
#24 |
Kostya Afendikov
#25 |
Чайный пьяница
А ещё лучше - волшебной коммандой debugger; (при этом не забудьте включить отладку скриптов у себя в браузере).
#26 |
не проходит короче эта строчка:
var result = resultXml.selectSingleNode("//q1:" + sAttributeName).nodeTypedValue; Как бы задать условие, чтобы она не выполнялась, если искомый атрибут null? |
#27 |
или как задать, чтобы в строке
var errorCount = resultXml.selectNodes('//error').length; errorCount становилось единицей в случае, если искомый атрибут null? |
#28 |
А как вытащить значение атрибута с типом дата?
#29 |
Kostya Afendikov
Точно так же, только потом его необходимо преобразовать в необходимый для себя
вот вариант "по-быстрому" var datec; datec = GetAttributeValueFromID("new_entity","{63802E36-49AB-DC11-94ED-000423AF733E}","new_daterate"); var year; var month; var day; year = datec.substr(0,4); month = datec.substr(5,2); day = datec.substr(8,2); crmForm.all.new_mydaterate.DataValue =new Date(year,month,day); |
#30 |
Сообщение от Bondonello
#31 |
А как присвоить Lookup-атрибут одной сущности Lookup аттрибуту другой сущности? Т.е. допустим у аккаунта есть связь c TestEntity (N:1) и у контакта есть связь с TestEntity (N:1). Как на форме создания (обновления) контакта при выборе Parent account подставить автоматически связь TestEntity аккаунта?
На OnChanged событии аттрибута parent_account я уже получил GUID TestEntity выбранного аккаунта. Осталось только присвоить crmForm.all.testentityid.DataValue значение. Но DataValue в этом случае NULL (пользователь ничего не выбрал). Кто-нибудь сталкивался с такой задачей? Есть идеи? Спасибо. |
#32 |
Чайный пьяница
Поэтому используйте примерно такой код: Код: var datec;
var year;
var month;
var day;
month = datec.substr(5,2) - 1;
#33 |
Чайный пьяница
Сообщение от SilentBlaze
#34 |
А каким образом,наоборот, присвоить атрибут из "подвязанной сущности" атрибуту "главной", ведь там нет лукапа.
#35 |
Чайный пьяница
2. Выполнить апдейт полей родительской сущности по полученному айдишнику родительской записи средствами веб сервисов.
Эмо разработчик, сначала пишу код, потом плачу над его несовершенством. Подписывайтесь на мой блог, twitter и YouTube канал. Пользуйтесь моим Ultimate Workflow Toolkit Последний раз редактировалось a33ik; 14.04.2009 в 15:14. |
#36 |
Кстати, так вопрос и не решился, если искомый атрибут null?
#37 |
Я вопрос с null решил так:
telephone1= resultXml.selectSingleNode("//q1:telephone1"); if ( telephone1 !=null ) crmForm.all.telephone1.DataValue = telephone1.nodeTypedValue else {crmForm.all.telephone1.DataValue = null} работает. |
#38 |
Молодцы =))
А с Гуидами в Пиклистке.... жжете.. ржал минуты 2 рассмешили =)))) Спасибо! |
#39 |
Чайный пьяница
Не совсем понял, почему посмешило. Можете объяснить?
