mfp: Solving the element ID problem
Источник: http://blogs.msdn.com/mfp/archive/20...d-problem.aspx
============== We've had feedback from many sources (comments in this blog, emails, in-person meetings, partner advisory board, etc.) that we should fix the element ID problem in AX - the sooner the better. Thank you very much for this feedback. This post is intended to give a bit of background on this subject. The element ID problem in AX causes pain on two fronts:
Business Data: IDs are persisted in the business data base. Any change to IDs would require upgrade scripts. To make matters even worse, IDs are also stored in unstructured blobs; making identification and migration even harder. Business Logic: Business logic uses IDs. Both Microsoft's business logic; but certainly also the business logic in solutions authored by partners around the world. Changes to IDs would impact all this business logic. Kernel: The implementation of the kernel used IDs heavily. Changing data type or dropping IDs totally would require rewrite of large portions of the kernel.The kernel provides the API for converting IDs to names and back again. Application model: IDs (and Names) are stored in the Application Model. IDs are used as references between model elements and IDs bind customizations to the original element. Whatever changes we make, we cannot break the references in the model. Getting challenges like this is what I love about my job. ============== Источник: http://blogs.msdn.com/mfp/archive/20...d-problem.aspx
