Старый 02.04.2007, 14:07   #1
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
Так... Первый параграф с небольшими стилистическим изменениями... Прошу рассматривать, как мое предложение, не более того
What's It All About?
I have been talking to consultants and developers who works with DAX and I know that the issues regarding inventory closing and stock cost calculation have become one of the severest for the majority of implementation projects. Users treat the inventory closing as a ‘black box’ delivering various results every time it's run depending on the phase of Moon. In my opinion, this is caused by the lack of information, which is dispersed across the whole documentation. Furthermore, some tricks of this procedure are not documented at all and need to be discovered with the cut-and-try method or by studying the source code of inventory closing.
In this article I'll try to explain in detail how this procedure works and to guide you through some other issues related to the cost calculation. A part of the information has been collected from different documents about DAX; another part captures my own experience gathered while working with Axapta 3.0 and reverse-engineering its source code. I haven’t verified everything in the version 4.0 but - according to my analysis of the source code – the algorithm hasn’t been changed significantly.
This document is addressed to experienced DAX (formerly Axapta) consultants and software architects who have questions on the subject. The reader should understand basic ideas of the Trade and Logistics module and should have already tried to run the inventory closing.
Старый 02.04.2007, 15:27   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от Maxim Gorbunov Посмотреть сообщение
«consultants and developers who work with DAX»?
Все-таки, мне кажется, нельзя называть reverse-engineering'ом «анализ исходных кодов», о коем идет речь в оригинале статьи. Reverse-engineering - это скорее воссоздание исходных кодов на основании какой-то другой информации.
Наверно, в свете последних обновлений эту фразу стоит как-то изменить.
Старый 02.04.2007, 15:48   #3
Maxim Gorbunov
Упс... Согласен. Промахнулся.
А как назовем? Предлагайте.
Предлагаю редактировать статью дальше здесь: http://erpkb.com/Axapta/Cost
Первоначальный вариант я уже туда забросил.
faq, закрытие склада, полезное, себестоимость
Denis Fedotenko: Себестоимость и длинные производственные заказы Blog bot DAX Blogs 13 21.11.2013 16:57
Пересчет и закрытие склада. Jony DAX: Функционал 11 30.03.2010 18:50
InventTransIdReturn и Закрытие склада DenisS DAX: Программирование 15 03.12.2008 09:02
Закрытие склада. Параметр "Спецификация" DenWolf DAX: Функционал 0 05.06.2006 14:46
Закрытие склада в основной и вторичной валюте, отключенная корреспонденция счетов May DAX: Функционал 1 02.04.2004 13:25
Часовой пояс GMT +3, время: 15:58.
