Старый 13.09.2017, 17:11   #1
Art Of Creation: Dynamics AX: No metadata class defined for data contract object
Источник: http://www.artofcreation.be/2014/03/...ntract-object/
When creating and using services you can get the following error:
When you get this error it means that you are trying to use a type as a data contract that is not a valid data contract type.
Valid type are primitive types, tables and views, data contracts, containers, EDT’s, and collections (For a full list of supported types, check the Using Data Contracts in X++ [AX 2012] page on msdn.
To figure out what data member is causing a problem, put a breakpoint at the throw error in the SysOperationDataContractInfo.newParameterInfo() method. When the breakpoint is hit, the data member will be displayed in the _parentMethodParameterName variable and the type in the dictClass variable.
To solve the problem, use a type that is supported. If you want to pass a class, either pass it as a container (e.g. using a pack() method), or better yet, define the class as a data contract with data members.
Note: I’ve also seen this error pop up when the data contract wasn’t correctly compiled. Simply put a breakpoint as described above to figure out what data contract is causing the problem and compile the class (both X++ and CIL). Keep in mind that you might have to compile forward if the class is extended, or do a compile forward on the class that it extends.
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 03:28.
