Старый 18.12.2015, 13:11   #1
mfp: X++ in AX7: Inline variable declarations
Источник: http://blogs.msdn.com/b/mfp/archive/...larations.aspx
What would you pay to be able to do this in X++?
for(int i = 1; i  0)
    int positiveInt = i;
Or this:
if (applyInterestRate)
    real rate = this.getInterestRate();
    result = result * rate;
if (applyExchangeRate)
    ExchangeRate rate = this.getExchangeRate();
    result = result * rate.ExchangeRate;
Finally, we can:
  • Declare variables close(r) to where they are used,
  • Variables are scoped by the block in which they are declared, and
  • Variable names can be reused in another scope.
The price: Join the ranks of AX7 developers!
Note: Whenever you consider using inline variable declarations – consider extracting the code into a smaller method instead. Here is why.
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 TECHNICAL PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
Последний раз редактировалось mazzy; 18.12.2015 в 17:17.
mfp: X++ in AX7: Const keyword Blog bot DAX Blogs 0 17.12.2015 12:02
mfp: X++ in AX7: Static event subscription Blog bot DAX Blogs 0 11.12.2015 11:11
mfp: X++ in AX7: Type declarations can be 80 characters Blog bot DAX Blogs 0 08.12.2015 03:18
mfp: X++ in AX7: The var keyword Blog bot DAX Blogs 43 04.12.2015 10:19
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 16:08.
