Старый 20.08.2021, 15:11   #1
crmtipoftheday: Tip #1405: Unable to assign license to a guest user
Источник: https://crmtipoftheday.com/1405/unab...o-a-guest-user
B2B collaboration is great. For example, you can share a canvas app with guest users or invite users to use with Azure Active Directory B2B collaboration . One of the steps in the process is adding B2B collaboration users in the Azure portal. But when you try adding a license assignment you maybe faced with the unexpected “License assignments failed”:
Why would assignment of a free license fail? The reason is revealed when you click “License assignments failed” link:
License cannot be assigned to a user without a usage location specified
Albert Einstein, 1948
That’s right, just edit the user profile and tell Azure where the user is and you’ll be able to assign the license, free or otherwise.
Cover photo by Elijah Macleod on Unsplash
crmtipoftheday: Tip #1369: New user cannot see environment Blog bot Dynamics CRM: Blogs 0 24.06.2020 15:11
crmtipoftheday: Tip #1309: 213 revisited: Embedded user role list Blog bot Dynamics CRM: Blogs 0 07.10.2019 16:47
crmtipoftheday: Tip #1276: Do my Dynamics 365 users need a Microsoft Flow license? Blog bot Dynamics CRM: Blogs 0 21.06.2019 19:12
crmtipoftheday: Tip #1080: Setting KPIs for user adoption Blog bot Dynamics CRM: Blogs 0 21.02.2018 04:31
Часовой пояс GMT +3, время: 03:16.
