Старый 31.03.2019, 15:19   #1
daxrunbase: Trace database cleanup in an efficient way
Источник: https://www.daxrunbase.com/2019/03/3...efficient-way/
The Trace parser is an excellent tool for troubleshooting business functionality within Microsoft Dynamics AX 2012 and Dynamics 365 for Finance and Operations. Your Trace database can quickly grow large and it does affect the tools’ performance adversely. Removing the old trace collections one-by-one is time consuming. You could utilize a stored procedure for cleaning up your AX trace database...
The post Trace database cleanup in an efficient way appeared first on DAXRunBase.
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: AX for Retail: Manage data cleanup task in POS database Blog bot DAX Blogs 0 12.02.2012 16:11
Microsoft Dynamics NAV Database Archive for all Country Versions Blog bot Dynamics CRM: Blogs 0 11.03.2011 18:43
axinthefield: Database Mirroring with Dynamics AX Blog bot DAX Blogs 1 20.01.2011 10:54
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
Часовой пояс GMT +3, время: 18:11.
