Старый 06.09.2018, 02:35   #1
gustafwesterlund: Hybrid NTLM Server Side Sync and Exchange 2013 Cert secrets
Источник: http://gustafwesterlund.blogspot.com...-sync-and.html
The server side sync is a technology for connecting Dynamics 365 CE to an Exchange server. When connecting an Online Dynamics 365 to an onprem Exchange there are some requirement that need to be met. These can be found here: https://technet.microsoft.com/sv-se/.../mt622059.aspx
Piping data to and from Exchange and Dynamics
By Quartl [CC BY-SA 3.0], from Wikimedia CommonsHowever, I just had a meeting with Microsoft and based on the version shown 2018-09-05, they have now added some new features that they haven't had time to get into the documentation yet.
Some of the most interesting parts of the integration is that the it requires Basic Authentication for EWS (Exchange Web Service). Of the three types of authentication available Kerberos, NTLM and Basic, Basic Authentication is, as the name might hint, the least secure. Hence it is also not very well liked by many Exchange admins and may be a blocker for enabling Server Side Sync in Dynamics 365.
In the meeting I just had with Microsoft, they mentioned that they now support NTLM as well! That is great news as that will enable more organizations to enable Server Side Sync.
There is still a requirement on using a user with Application Impersonation rights which might be an issue as that can be viewed as having too high rights within the Exchange server. For this there is currently no good alternative solution. I guess making sure that the Dynamics Admins are trustworthy and knowing that the password is encrypted in Dynamics might ease some of that. But if the impersonation user is compromised, then a haxxor with the right tool or dev skills could compromise the entire Exchange server.
Microsoft also mentioned another common issue that can arise with the Outlook App when using SSS and hybrid connection to an Exchange 2013 onprem. It will show a quick alert saying "Can't connect to Exchange" but it will be able to load the entire Dynamics parts.
This might be caused by the fact, according to Microsoft, that Exchange 2013, doesn't automatically create a self-signed certificate that it can use for communication. Hence this has to be done.
This can be fixed by first creating a self signed certificate and then modify the authorization configuration using instruction found here . Lastly publish the certificate. It can also be a good idea to check that the certificate is still valid and hasn't expired.
I will see if I can create a more detailed instruction on this later.
Gustaf Westerlund
MVP, Founder and Principal Consultant at CRM-konsulterna AB
www.crmkonsulterna.se
stoneridgesoftware: Internal Emails Sent to a Queue in Dynamics CRM are not Tracked by Server-Side Sync Blog bot Dynamics CRM: Blogs 0 28.07.2016 19:16
Microsoft Dynamics CRM Team Blog: New Server-Side Sync Setup Guide Blog bot Dynamics CRM: Blogs 0 07.11.2015 02:30
emeadaxsupport: AX for Retail R3: Training Videos for Commerce Data Exchange Async Blog bot DAX Blogs 0 02.07.2015 01:14
gustafwesterlund: Server side Sync Trouble shooting Blog bot Dynamics CRM: Blogs 0 22.04.2014 18:11
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
Часовой пояс GMT +3, время: 01:43.
