Старый 16.09.2015, 17:11   #1
axmfg: Overproduction in Microsoft Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axmfg/archiv...s-ax-2012.aspx
Overproduction is the term used in Microsoft Dynamics AX 2012 for reporting a production or batch order as finished when the quantity produced is greater than originally planned. This is a common scenario in the process industry and can be caused by many factors, for example, potency and yield.
When you produce more items than planned for a production or batch order, you will get the following blocking error: Quantity reported as finished exceeds the quantity started.
In order to allow for overproduction, you have to select the parameter Accept error in the Report as finished parameters. This will bypass the quantity validation check and then allow for overproduction.
For companies that use the Manufacturing execution module in Dynamics AX2012, there is a more advanced support for overproduction. In this module, you can set up a quantity validation based on different criteria. For example, you can accept overproduction in percent based on the planned quantity, the started quantity, or the quantity reported on the previous operation.
Report as finished from a handheld device in Microsoft Dynamics AX 2012 R3
With the introduction of the new warehouse management capabilities in Microsoft Dynamics AX 2012 R3, it is possible to Report as finished from a handheld device. The only disadvantage of using this capability is that you can’t overproduce. The user will be blocked by the error: Quantity reported as finished exceed the quantity started, and have no option to override the setting.
Enable overproduction with KB 3034999
In this Hotfix, we leverage the quantity validation parameters originally built for the Manufacturing execution module. So the parameters now support the scenario where the user needs to report overproduction from a handheld device.
To show an example of how overproduction is reported, I have changed the demo script for CU8 “SCM Demo Script – Batch orders and WMS integration”. I have changed the section:
DEMO: REPORT THE PRODUCTS AS FINISHED AND MOVE THEM TO LOCATION FOR FINISHED PRODUCTS
The following diagram shows the complete logic. The logic was originally only applicable for reporting overproduction from the job registration form in the Manufacturing execution module, but is now applicable for the scenario where the user needs to report overproduction from a handheld device.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 30.04.2016 10:26
mfp: Microsoft Dynamics AX 2012 is here! Blog bot DAX Blogs 10 04.08.2011 17:11
Часовой пояс GMT +3, время: 16:09.
