Старый 07.06.2011, 19:11   #1
daxline: rowCount() method on table buffers.
Источник: http://feedproxy.google.com/~r/blogs...e-buffers.html
At first glance, this method looks like that it will return the number of rows selected on a table. But that is not the case. If we run the following lines, the result will be always -1
select custTable where custTable.custGroup=='10';
print custTable.rowCount();
The issue is that this method is to be used only with set based operations on the database. So, if you are using insert_recordset, update_recordset or delete_from, the rowCount() method will return the number of rows created, updated or deleted. Here is a sample job that shows this in action.
static void rowCountJob(Args _args)
CustTable custTable;
MyTable myTable;
ttsbegin;
insert_recordset myTable(AccountNum, PartyId, CustGroup, Currency)
select AccountNum, PartyId, CustGroup, Currency
from custTable
where custTable.CustGroup== '10';
// Prints 13 as 13 records with custGroup == 10 were inserted from CustTable
print myTable.RowCount();
update_recordset myTable
setting Currency='CNY'
where myTable.AccountNum like '11*';
// Prints 4 as 4 record exists( 1101, 1102, 1103, 1104)
delete_from myTable
where myTable.AccountNum like '9*';
// Prints 1 as 1 record exists (9024)
delete_from myTable;
// Prints 12 as 12 records are all that exists.
ttscommit;
pause;
Последний раз редактировалось Poleax; 08.06.2011 в 10:02. Причина: оформление
daxline: Performance – find() vs. exist() method Blog bot DAX Blogs 0 28.01.2011 23:14
daxline: Enhanced SysTableBrowser - View only the fields you want in table browser Blog bot DAX Blogs 0 28.01.2011 23:14
exist method on temporary table ist DAX: Программирование 3 31.03.2010 10:16
PatrickChua: Temporary table Blog bot DAX Blogs 0 04.05.2009 14:05
method insert() when insert table from outside susenyudha DAX in English 1 29.08.2008 18:51
Часовой пояс GMT +3, время: 05:51.
