Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 15.04.2011, 15:57   #1
ist is offline
ist
AX 2009 Version Control System
Hello,
I have a problem with VCS in AX2009. The problem is that when some (except me) tried to "Check out" the table InventTable the system of version control says that the object is locked (checked out) by user Admin i.e. by me, but it's not true. See attached screenshot:
In the context menu I have a choice "Check out". If the object has been checked out by me in the context menu I didn't have this choice. Instead I would have "Check in. I remembered that in the menu Development tools I have seen submenu "Version control". In this submenu I choose "Pending objects". See attached screenshot.
In the form I see table InventTable. In the column Action I see "Delete". I try to "Check in" object by coresponding button, but without result. After that I try to "Undo check out" again without effect. Other users still can't "Check in" the object. Ax trown the same message taht the object has been "Checked out" by me. I don't know how to resolve this problem. Please help.
Regards,
Старый 15.04.2011, 22:16   #2
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
Записей в блоге: 1
Do not use version control system
We had bad experience using it, including losing of modifications.
Старый 17.04.2011, 00:57   #3
ist is offline
ist
Hello everybody,
I found a solution of the problem. VCS keeps versions of the objects for each layer. The mentioned pending obeject has been checked out by me on the USR layer after that I deleted the copy of the object on the USR layer without to do "Check in. On the CUS layer in the context menu I have a choice "Check out" because I have not been Checked out" the object on this layer.So for this reason I can't to do "Check in" and "Undo check out" on the pendig objects form on the CUS layer. When I changed and went to the USR layer I did "Chck in" and InventTable disappeared on the pending objects form.
Regards,
Microsoft Dynamics AX 2009 White Paper: Migration of Microsoft Dynamics AX Version Control System content from Microsoft Visual SourceSafe to Microsoft Team Foundation Server Vadik DAX: База знаний и проекты 0 07.05.2010 12:03
mfp: Microsoft Dynamics AX 2009 White Paper: Integrating a Third Party Version Control System into Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 09.02.2010 17:05
Microsoft Dynamics AX 2009 White Paper: Integrating a Third Party Version Control System into Microsoft Dynamics AX 2009 Vadik DAX: База знаний и проекты 0 05.02.2010 10:27
Часовой пояс GMT +3, время: 16:34.
