Старый 04.12.2010, 01:11   #1
dynamicsaxtraining: How to convert label to a string
Источник: http://www.dynamicsaxtraining.com/kn...el-to-a-string
edit LabelString helpTextValue( boolean _set, LabelString _value ) { LabelString ret; Label label; xInfo inf; ; if( _set ) { CDT_MenuItemList.HelpText = _value; } if( isHelpTextControlActive ) ret = CDT_MenuItemList.HelpText; else { inf = new xInfo(); if( inf ) { label = new Label( inf.language() ); if( label ) ret = label.extractString( CDT_MenuItemList.HelpText ); } } return ret; }
dynamicsaxtraining: How to make data from temporary table available in form’s grid Blog bot DAX Blogs 0 04.12.2010 01:11
emeadaxsupport: How label flushing works under the hood Blog bot DAX Blogs 0 17.08.2010 16:05
dynamicsaxtraining: How the pallet height is calculated Blog bot DAX Blogs 0 21.01.2010 23:05
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
Malaysia: How to base on a given string class name to create the class' instance Blog bot DAX Blogs 0 15.08.2007 13:00
Часовой пояс GMT +3, время: 01:59.
