stoneridgesoftware: Expedite Security Role Testing Assignments After a Code Move in Dynamics AX
Источник: https://stoneridgesoftware.com/exped...n-dynamics-ax/
============== It is common throughout an ERP migration for the need to perform many code promotions and environment refreshes to a TEST or UAT system for eventual installation to Production. Not only is testing being performed on code, data, and functionality, but security roles and settings may also require validation. This can introduce a level of complexity in your testing scenarios because the users testing the roles may not necessarily “live” them or be representative of what they have in Production. Therefore, manual IT administration is needed after each data refresh to reassign users into their needed testing roles, as they will inherently match the system the data originated from. This can be especially problematic and time consuming if there are large numbers of people testing security roles. There is a shortcut to addressing this however and it involves setting up your desired “testing” security role assignments in one environment, exporting them, and further importing them into the target environment. The following steps can be taken to accomplish this. How to set up security role assignments, export, and import for testing in Dynamics AX: In our scenario, April Meyer is an accounts payable manager at Contoso Ltd. She is working on testing the security roles for her employees, one of which includes the accounts payable clerk role. In Production, the source of the data refresh, her security role assignments are as follows: ![]() In TEST, where the security role testing will occur, she needs to have the following security role assignments in order to test and validate functionality: ![]() Set up security role assignment The first step is to set up the desired security role assignment. This should ideally be performed in an environment that closely resembles the target, such as a development system that was copied from production. In our scenario, we are going to be performing the desired assignments in our TEST environment.
![]() Export user role assignments
![]() Moving into TEST Next, we’re now assuming that our TEST environment has been refreshed from Production and we need to update the security assignments for our testing users.
![]() Источник: https://stoneridgesoftware.com/exped...n-dynamics-ax/
