Старый 09.02.2010, 00:08   #1
Error: Multiple calls to CodeAccessPermission.Assert
Источник: http://alexvoy.blogspot.com/2010/02/...-calls-to.html
(S)\Classes\SkipAOSValidationPermission\assert
(S)\Classes\BatchRun\runJob - line 166
(S)\Classes\BatchRun\do - line 54
(C)\Forms\BatchRun\Methods\doBatch - line 18
Sometimes I got this error while working with Change based alerts batch processing. After that the status of the related job in batch list changed to Executing, and the only way to get rid of it was deleting that job.
This issue arises in [Classes]BatchRun.runJob method because of absence of closing revertAssert() method in case of exceptions after calling runas() method.
So, my solution is to comment the existing call of revertAssert()...
if (batchClass.runsImpersonated())
            // Ok to assert here because the user name comes from
            // the batch table
            runAsPermission = new RunAsPermission(batch.CreatedBy);
            runAsPermission.assert();
            // BP Deviation Documented
            runas(batch.CreatedBy,
                classnum(BatchRun),
                staticmethodstr(BatchRun, runJobStatic),
                [batchId]);
           // Alexey Voytsekhovskiy (SIS) (2010/02/08) (Demande #0074)
           // CodeAccessPermission::revertAssert();
        else
            BatchRun::runJobStatic([batchId]);
and move it after catching all kind of exceptions:
catch (Exception::UpdateConflictNotRecovered)
        isErrorCaught   = true;
        exception       = Exception::UpdateConflictNotRecovered;
    // in case of exception Permssion should be revert anyway!!
It allows to avoid multiple calls to CodeAccessPermission.Assert (there is another call far in this method) and see the log of the job ended with an error.
By the way, here is a short and sweet trick with multiple calls if needed.
paruvella: Tool for Tracing the DB calls from Ax-Client Blog bot DAX Blogs 0 04.02.2010 19:05
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM and Silverlight 2 direct calls sample Blog bot Dynamics CRM: Blogs 0 02.12.2008 05:19
CodeAccessPermission DAX 4 SP2 monk DAX: Программирование 3 03.09.2007 16:26
Greg: Dynamics AX: Making .NET calls from inside AX Blog bot DAX Blogs 0 02.04.2007 19:30
Часовой пояс GMT +3, время: 05:49.
