Старый 22.04.2021, 21:12   #1
Maximum Size for Business Events
Источник: http://alexvoy.blogspot.com/2021/04/...ss-events.html
Business Events help to integrate D365FO with other systems; they are supposed to be specific and small. But how exactly small should they be? What is the maximum size for one message?
If we take a look at the code, we will see that the maximum is driven by the type of Business Event End Point:
Some of these classes specifically set their max.
For example, BusinessEventsServiceBusAdapter even implements some logic here.
As per Flow and HTTP, it is defined as 1MB minus 4KB for the header.
So, we have two conclusions here:
- we have to check these hard-coded limits directly in the code, as they may be changed in future;
- if you need to send a chunk of information bigger than the maximum size, you'd better revise your solution. For example, instead of sending a file you can send just its Azure Storage locator;
- another option can be your own End Point;
Some useful links.
How to develop Business Events
How to use Business Events
Example of using Microsoft Power Automate (Flow) to integrate with D365FO via Business Events
german_nav_developer: Catch Me If You Can – try-catch für .NET in C/AL Blog bot Dynamics CRM: Blogs 0 22.09.2014 11:00
Nav developer: Table Information including Index information (Usage, Blocks and Reads) Blog bot Dynamics CRM: Blogs 0 25.08.2009 19:34
NAV Sustained Engineering Team Blog: Index Usage Query Blog bot Dynamics CRM: Blogs 0 26.02.2008 12:29
Часовой пояс GMT +3, время: 00:13.
