palleagermark: Label translations not showing in the label search dialog?
Источник: https://www.agermark.com/2020/01/lab...-in-label.html
============== Microsoft is now adding translated label files to the deployed developer boxes, which is supposed to make is possible to search for labels in other languages than en-us. I'm not sure if this is done for all models though. If the search doesn't work, the likely cause is that Microsoft didn't add the related XML file for the language under \AOSService\PackagesLocalDirectory\Package\Model\AxLabelFile. You can add these manually Here is an example for the Danish SYS label file: Now search is able to find the Danish labels: Источник: https://www.agermark.com/2020/01/lab...-in-label.html
