stoneridgesoftware: Six Overlooked, but Helpful Tools in Dynamics 365 Customer Engagement (CRM)
Источник: https://stoneridgesoftware.com/six-o...ngagement-crm/
============== ![]() Are you using the many helpful tools in Dynamics 365 Customer Engagement? I’ve found that many users rarely take advantage of the handy icons that are in plain sight – right at the top of CRM. If not, I’ll tell you more about them, so you can be more productive and use your CRM solution more efficiently. 1. Search ![]() Clicking on Search will open a text box for you to type a string to search. This will search all entities that have been set up for Search. Up to 10 entities can be set up, including custom entities. See your administrator to add or remove them. ![]() Results will be returned in columns, allowing you to click on the record you need. ![]() 2. Recently Viewed Items ![]() Clicking on this icon will show you the most recent views and records that you have visited in CRM. ![]() Click on the view or record to go directly to it. For views or records that you frequent, clicking the push pin will keep it in a handy location at the top of the list. 3. Quick Create ![]() Clicking this icon will give you a list of entities that have a Quick Create form. This is for when you are in a hurry and need to get a record created. Quick Create forms are set up by your administrator and are available based on your security role. 4. Advanced Find ![]() This option opens the Advanced Find window. It allows you to create a more advanced query to find the records you need. Advanced Find is a topic for another blog. 5. Setting ![]() This icon gets you to your personal settings. ![]()
![]() Clicking on your picture allows you to Edit the image and also log out of CRM. I hope you look at all these icons in a new way and take advantage of the helpful tools in D365 Customer Engagement, right in front of you! Источник: https://stoneridgesoftware.com/six-o...ngagement-crm/
