crmtipoftheday: Tip #1247: Why you should rename your steps in Flow
Источник: https://crmtipoftheday.com/1247/why-...steps-in-flow/
============== When you start using Flow, it is tempting to just add your triggers and actions and go, but there is one small detail you don’t want to forget–rename those steps. For those who don’t know, you can click the … on a step in Flow and select rename. ![]() This will then let you rename the action step to something that makes more sense than “Update record 3.” So why is that important?
![]() ![]() Bonus tip–name the steps first You may find the “rename” option is grayed out and you cannot rename a step. The reason for this is because other steps depend on this step, and you can’t rename a step if it is referenced in a subsequent step. ![]() Cover photo by unsplash-logoBrett Jordan Источник: https://crmtipoftheday.com/1247/why-...steps-in-flow/
