axatoz: Using Postman with D365
Источник: https://axatoz.wordpress.com/2019/03...man-with-d365/
============== We need the right tool for the job. Postman is a tool that often used to interact with Restful services (OData). Below is how you can setup postman to work with D365 (assuming you know how to setup on Azure side like tenant_id, client_id, client_secret) SETUP ![]() Setting up BearerToken Params tab ![]() Body tab grant_type: {{grant_type}} client_id: {{client_id}} client_secret: {{client_secret}} resource: {{resource}} ![]() ![]() Test tab var json = JSON.parse(responseBody); tests[“Get Azure AD Token”] = !json.error && responseBody !== ” && responseBody !== ‘{}’ && json.access_token !== ”; postman.setEnvironmentVariable(“bearerToken”, json.access_token); ![]() ![]() TEST ![]() ![]() ![]() ![]() OR ![]() ![]() ![]() ![]() ![]() ![]() Postman with CRUD operations Insert Operation Header tab Authorization = Bearer {{bearerToken}} If-None-Match = null OData-Version = 4.0 Content-Type = applicatin/json Accept = application/json Odata-MaxVersion = 4.0 ![]() Body tab ![]() Result ![]() Источник: https://axatoz.wordpress.com/2019/03...man-with-d365/
