ariste.info: The mystery of the non-filtering query
Источник: https://ariste.info/en/2019/02/the-m...ltering-query/
============== There’s no mystery here but a misperception. Recently, a colleague found a little issue when using an AOT query to feed a view with a range dynamically filtered using a SysQueryRangeUtil method. Recreating the issue The query is pretty simple, only showing ledger transaction data from the GeneralJournalEntry and GeneralJournalAccountEntry tables. A range in the Ledger field from the … Continue reading The mystery of the non-filtering query → La entrada The mystery of the non-filtering query se publicó primero en ariste.info. Источник: https://ariste.info/en/2019/02/the-m...ltering-query/
