sinedax: 8.1.3 Platform Update 23 Installation Issue - Dynamics 365 for Finance & Operations LBD
Источник: http://sinedax.blogspot.com/2019/02/...tallation.html
============== Hi all, in the last days I tried to install the 8.1.3 Platform Update 23 version on my F&O LBD Environment but I raised some error. Really thank you to Mohamed Zaki and Renaud Paquay for helping me to address the resolution. AOS Application Error: Application: AXBootstrapper.exe Framework Version: v4.0.30319 Description: The application requested process termination through System.Environment.FailFast(string message). Message: RunAsync failed due to an unhandled exception causing the host process to crash: System.Management.Automation.RuntimeException: Exception calling "GetTypes" with "0" argument(s): "Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information." ---> System.Management.Automation.MethodInvocationException: Exception calling "GetTypes" with "0" argument(s): "Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information." ---> System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information. at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) Reason: AxBootStrapper is trying to load the netstandard.dll assembly from the GAC. Resolution: You need to install the netstandard.dll to your GAC on all AOSs. For each AOS, go through C:\Program Files (x86)\Microsoft SDKs\Windows\v8.1A\bin\NETFX 4.5.1\ and run the following CMD command: gacutil.exe -i " You can find the DLL to the Agent path \\....WP\EnvName\StandaloneSetup-xxxxxxx\Apps\AOS\AXServiceApp\AXSF\Code\bin\ I guess the hotfix coming soon! Till soon! Источник: http://sinedax.blogspot.com/2019/02/...tallation.html
