erconsult: Copy-paste with keyboard script 2: from Excel to D365FO
Источник: http://erconsult.eu/blog/copy-paste-...cel-to-d365fo/
============== Again an entity was missing in D365FO to import the data, this time a custom one. Building upon my work Copy-paste automation in D365 FO with a keyboard script, I created a Wunderwaffe script to copy a simple table with a Code and a Description directly from Excel into the D365FO browser window. Close all other windows and put the browser with D365FO and Excel side by side. Place the cursor in Excel in the Code column at the first row to copy, then hit Ctrl-J. The script will start copying data from Excel and pasting records in D365FO by switching windows forth and back: ^j:: ; --------- Place the focus on the code column in Excel, start with Ctrl-J Loop 200 { ; --------- Copy the content of the Code from Excel Send, ^c Sleep, 500 ; --------- Switch the window: Alt-Tab Send, !{TAB} Sleep, 1000 ; --------- Create a new record in the D365FO window Send, {Alt Down} Sleep, 500 Send, n Sleep, 500 Send, {Alt Up} Sleep, 1000 ; --------- Go to the next field and back in the D365FO to get into the edit mode Send, {TAB} Sleep, 1000 Send, +{TAB} ; --------- Paste the code Send, ^v ; --------- Switch the window and go back to Excel Send, !{TAB} Sleep, 1000 ; --------- Copy the content of the Description column from Excel Send, {Right} Send, ^c Sleep, 1000 ; --------- Switch the window for D365FO Send, !{TAB} Sleep, 1000 Send, {TAB} Sleep, 500 ; --------- Paste the description Send, ^v ; --------- Switch the window for Excel Send, !{TAB} Sleep, 1000 ; ---------Scroll down to the next record, and repeat the cycle Send, {Down}{Left} } Return ; Press F1 in panic F1::ExitApp The post Copy-paste with keyboard script 2: from Excel to D365FO appeared first on ER-Consult. Источник: http://erconsult.eu/blog/copy-paste-...cel-to-d365fo/
