d365technext: Deploy package using LCS
Источник: http://d365technext.blogspot.com/201...using-lcs.html
============== Deploy package using LCS Using following steps you can create deploy-able package and deploy through LCS. Step-1 Open Visual studio and click on Dynamics365 Menu and select create deployment package from the deploy menu item. Step-2 Select your model and set the output path of the model and click OK. Step-3 Login to LCS then navigate to your project. Ste-4 click on hamburger icon and select Asset library. Step-5 Now select software deploy-able package and click on + Icon to add your custom package. Step-7 click on Add file button to upload your deploy-able package. Step-8 Now click on browse and select package then click on uplaod. Step-9 You can find the package in the tab of software deploy-able tab Once package uploaded successfully. Step-10 Once LCS mark package as valid. then goto your environment. Step-11 Now click on Maintain and select apply update. Step-12 Select your package and click on apply. Package deployment will start in few seconds . LCS will show you progress of every steps. Once package completed sign Off the package, So it will visible to you on production deployment as well. Please feel free to contact me if you are facing any issue during implementation of this blog. Источник: http://d365technext.blogspot.com/201...using-lcs.html
