crmtipoftheday: Tip #1129: Add features to Dynamics 365 Portal
Источник: https://crmtipoftheday.com/1129/add-...cs-365-portal/
============== Even the best of us occasionally make the wrong choice when provisioning Dynamics 365 Portals, especially when Customer Self-Service seems like an obvious all-encompassing choice. Except that it is not. Take, for example, the case of Feridun “Best Twitter Handle for CRM MVP” Kadir: Problem I have a D365 instance with the customer self-service portal installed. Is it possible (and if so how please) to add Ideas (which, I believe, is in the community portal solution) to the D365 instance and have Ideas forums appear in the same website that is linked to the customer self-service portal? Solution As luck would have it, Microsoft Senior Program Manager, Dileep “Mr Portals” Singh, was able to spare some time to provide step-by-step instructions: In terms of guidance, I always suggest starting with community template (see, what did I tell you! – t.j.) as it has all customer self-service functionality + extra, and hide the functionality which you don’t need. So if that’s an option in your project, I will suggest doing that. Otherwise:
Tîpp Jäår $0.02 Note: these steps aren’t published yet in any specific documentation, however, that may change if there are more requests coming in for this. I guess additional votes for the WebSite Copy Tool wouldn’t go unnoticed so go ahead and add your voice! Facebook and Twitter cover photo by Drew Patrick Miller on Unsplash Источник: https://crmtipoftheday.com/1129/add-...cs-365-portal/
