waldo: Function Overloading in AL
Источник: https://dynamicsuser.net/nav/b/waldo...rloading-in-al
============== I haven’t been blogging much, lately. But in my defence – I put quite some time in another community project, which I blogged about in my previous post (and will blog about in quite a few coming posts…). To keep up the pace of writing at least one post each month (which I have been able to do so for the past 11 years or so) – I HAD to put something up urgently ;-). And it’s going to be about a new possibility we have in the AL language, which is often forgotten: Function Overloading In C/AL we never had the ability for overloading a function. You know: using the same function name with a different context (parameters). Now – YES WE CAN! It’s all pretty well described on docs: https://docs.microsoft.com/en-us/dyn...verload-method How cool is that? Can I overload more? Overloading my own functions is nice. But the question I always get in my classes is: can we also overload functions from the default app – or from any dependent app for that matter. Well – in short: YES WE CAN! Let me give you a simple example: ![]() I’m overloading the default method “CreateAndShowNewInvoice” on the vendor table with a different context (Text-parameter). So I have a completely new method, with the same name. One thing that would be interesting is to be able to extend on a main method like that – and that’s what I basically doing above – I call the main method, and extend it with my own code. Dependencies As this works on the default app, you can expect it does work on dependent extensions as well. I created an example on my github, which you can look into. Extension A implements a new method on the Item table (or should I say “class” ;-)): ![]() Extension B has a dependency on A, and implements a slightly different implementation of that method. You see: same function name, different parameters ![]() To Test the overload, I created a subscriber to logInManagement .. And you’ll see that B basically extended the implementation of A… ![]() And yes, I hear you – One should test with a test-codeunit. So I created that for you as well :-). ![]() And if you’re using the CRS AL Language Extension, it’s easy. Just run the C/AL Test Tool from VSCode from the command palette: ![]() And there you go! ![]() ![]() Enjoy! Источник: https://dynamicsuser.net/nav/b/waldo...rloading-in-al
